ok so I'm attempting to do this setup on my 92 ex coupe and I ran into a few problems. I purchased, what I thought were, 98 CL 2.3 hubs but I received 99 Cl 3.0 hubs. I went to go press on the new wheel bearing I ordered for a 90-93 accord. I found out it wasnt lining up.... so we got out the digital OD gauge. We figured out that the hubs and bearings didnt match up to each other. We cross referenced the numbers for the OD on the hub and found out it was a 3.0 CL hub. So I was wondering whats the difference in the 2.3 compared to the 3.0 hubs. If i bought 3.0 bearings and rotors will this work or will be completely different? Isn't the 3.0 ROH too? the axle splines are the same, we checked to see if the accord axle fit in the 3.0 hub and it did. Also the width of the 3.0 is longer than the 2.3 so will this matter? how? i need help. thanks
Need help with ROH conversion
the 3.0 hub is a larger diameter and also a little longer, IIRC.
which obviously, it doesnt work, as youve found....
unless you want to start machining things to fit, just get 2.3 hubs.
this has been gone over MANY times, with some people actually purchasing both, to make the comparisons. it isnt gonna work lol.
ok thanks. yea, i've tried searching threads and posts about the conversion. I know everyone says get the 2.3 hubs. But i was curious for what reason why doesn't the 3.0 hub work, I know the 3.0 bearing must press in there. Is there a fittment issue? I heard ppl say stay away from the 3.0 but I haven't heard for what reason. I'm goin to get the 2.3 ones once i send back my 3.0 hubs.
