Ok fellas, Im in the middle of my f22 auto to manual swap and Im having a hell of a time trying to get some one to weld for me. I can weld myself but most welders out there uses 220volts. I was told that a welder that uses 110volts would not be sufficient for what Im trying to do. I was thinking If I can drill into the bracket and side of the fenderwell I should be able to bolt on this bracket instead of welding? I would like to know your opinion on this situation.
Can I drill and bolt down the M/T bracket instead of welding??
Originally posted by plee3 View PostOk fellas, Im in the middle of my f22 auto to manual swap and Im having a hell of a time trying to get some one to weld for me. I can weld myself but most welders out there uses 220volts. I was told that a welder that uses 110volts would not be sufficient for what Im trying to do. I was thinking If I can drill into the bracket and side of the fenderwell I should be able to bolt on this bracket instead of welding? I would like to know your opinion on this situation.My inferiority complex isn't as good as yours.
Why don't you rent a gas powered welder/generator? Something like this
Originally posted by tonymontana1204 View PostYou might as well zip tie the damn thing in there, its going to rip like its nothing.
weld for me
under the hoodNO matter how many times we downshift vtec is on our side.
i thought about the same thing, using at least 4 bolts, one in each of the flat tabs...
only problem is that there is nothing solid to bolt them onto (just sheet metal), and i doubt that youd be able to get nuts onto the backside, because that area is sealed in.
welding is really the only way...
Originally posted by cp[mike] View Posti thought about the same thing, using at least 4 bolts, one in each of the flat tabs...
A decent 110 welder will do the job.
I might be thinking of a civic AT-->MT conversion here, but I thought you could use the same chassis mount, and just redrill the hole that the mount bolt goes through?
If this is the chassis mount:
............at-> O |
mt-> O.............../
we are talking about the right side mount correct?Last edited by racerpat94; 10-21-2008, 05:56 PM.
a 110v should be fine, and just do all the edges, itll "meet or exceed" oem specs lmao.
Yes i thought A 110V would do just fine. I really appreciate you guys opinion! This is very helpful. Right now I got he car in the air, axle nuts are loose (I used a rachet set thats the next size after 1/2, worked excellent) pedals switched, ECU switched, and everything off the top to get to the trans. Will keep you guys posted.
U can also Use the tranny mount from a 5 gen accord or any 92 and up prelude. I did my auto to 5 speed converstion on my 4 gen wagon, and used the 5 gen tranny mount and just shimmed the other side to level out the engine. I haven't had any problems out of it at all, but I can tell U if your car is droped og with the accord mount and not the prelude mount because with the swap it will make your engin lower by like 3/4ths of a inch if I'm not mistaken. GOOD LUCK!
OH, also depending on what mount and what tranny U have u might have to Tap the trans to use the mounts, and I found a thread on here where they sell the swap mount kits. The set of 3 mounts was like 275 i think and thier made to order so if your in a rush that isn't the wayLast edited by Rasta Wagon; 10-21-2008, 11:18 PM.
