Ok I finally got some pictures. If you look closely it still has the factory floormats and bra. I can't wait to pick it up. Ok let me figure out how to post pictures.
New Accord new member many questions
why is it the seattle silver & burgundy cars that are found in perfect condition?
anyway i would like to support the lube-the-cylinders idea, though ive done it with PB Blaster. it likes to stick to all of the cylinder walls and it is a GREAT rust solvent, i had rusty cylinders that cleaned up perfectly. but if yours are not rusty just possibly dry, getting them wet and turning it over by hand would be a very good way to make sure your rings dont get damaged.
but good find, id say the critical rubber engine components shoudl be replaced, all fluids changed, and a full tuneup.
Very nice.
Hell of a deal!
I agree with mike, all the rubber bits should be replaced as well. You'll put a bit into it, bringing it back to life, but with 50k on the clock, itll run like a top.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Holy shit thats nice. Not a spec of rust that i can see.
Other then the timing belt needing to be replaced. i would highly recommend that you take a look at the fuel pump itself. When sitting for long ammounts of time, pumps tend to take wear and tear on seals. You may need to replace that as well if it doesnt start. Make sure however it does get power, and that you hear it working when you put it to accessory.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
