my whole trunk is wet, I'm trying to fix it before I put some sound deading material and I can't figure out why it's wet.
Why is my trunk wet?
Originally posted by bigoskii View Postmy whole trunk is wet, I'm trying to fix it before I put some sound deading material and I can't figure out why it's wet.
BWAHAHHAHAHA Because you own a fourth gen accord! Welcome to the club!
try removing the weatherstripping, check the sheet metal lip it goes on for bends or kinks, check the seal itself for damage. If that doesn't help, get in the trunk with a flashlight and have a friend hose it down until you see the leak.
was probably in an accident, check your carfax report. rear quarter panel had to be fixed and or trunk lid was bent and was hammered stragiht. there is probably a gap down the left line, stick a towel or piece of paper and close ur trunk if u can see the paper or towel through the line then it is not flush and will leak.
There are gaskets behind the taillights, they're probably GONE. Replace them and see if it still leaks. Or go to the JY and take some. you can fold them up and put them in your pocket so they'd be free
I vote on tail lights.
That is the bane of my leaking trunk. It always seems to be the outside tail light. I just take the thing off there, use a bunch of 3M Weatherstrip Adhesive(The Yellow stuff that looks like gorilla snot) and stick it back on. Use a lot so you don't have to worry. If you do it my way, lets hope you never have to take it back off for any reason, because it will be a mother to get off of there.
its usually the tail light gaskets.
second most commonly its the rust holes in the corners letting water in lmao.
either those, or the lower trim seal of the rear window.
sometimes the antenna, or the rubber seal around the trunk.
if you cant track down the source, drilling holes or removing the rubber plugs right where the water collects first usually lets it drain pretty quickly so it stays dry... but that may not work too well if you plan to put deadening over it...
mine leaked, turns out my trunk lid was bent and the right side wasn't sealing right. so me and a buddy twisted it back to where it should be and readjusted the the trunk latch so it would close a little tighter. i haven't had any water in it since, but then again it hasn't rained much lately...
I would try the tail light seals first and then look at the trunk seal along with the antenna seal. Other than that maybe look at the rear of the car in the trunk there should be 2 caps on the inside...for some reason mine were missing and thats where I was getting water in my trunk. They are circular caps...2 of them
Matt
