I am interested in buying a 92 cb, the only thing it needs is a clutch, both of my other cb's are automatics so i dont have any experience with 5 speeds, anyone have a close estimate? any help appreciated
How much would clutch cost?
if youre having it done, youd probably be best off calling local shops that youd be bringing it to, and asking them for their average rate for a honda clutch job, since it varies.
Originally posted by InFamouz Cb7 View PostI am interested in buying a 92 cb, the only thing it needs is a clutch, both of my other cb's are automatics so i dont have any experience with 5 speeds, anyone have a close estimate? any help appreciatedLast edited by 90goldcoupe; 06-23-2008, 05:55 PM.
Originally posted by brianh1290 View Postyou can get a stage 1 racing clutch on ebay for a 92 cb7 for around 90 dollars.
You can get the clutch itself for anywhere between $50 and $700... or more. Get an Exedy OEM replacement clutch. Inexpensive, and it'll work fine.
Putting it in can be a pain in the ass (get mike's mom to help... she makes it much easier!) If you can afford the downtime to figure it out, get a manual and go to work. It's not hard... just fairly time consuming, especially for a beginner.
You'll need to get the flywheel resurfaced, or replace it with a new one. You might also want to look into replacing the master and slave cylinders (which will require bleeding the system... another pain in the ass.)
Also, DO NOT use an aftermarket throwout bearing. I was too lazy to get an OEM one, and I used the one in my clutch kit. Now people think I don't know how to drive, because it makes a godawful noise in 1st.
Theyre not expensive at all. like 90-200 something. If your going to do it on your own, Get some homies and clear a saturday.I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!
