connector ID's for engine bay
    Hey guys, I took out my AC a while back, and I later heard that some of the connectors on the fenderwall/strut area of the engine bay are for the AC system. If anyone can point out which ones are which that would be greatly appreciated.
    Andy
    ^^click it or ticket^^
    you shoudl be able to find a pair of rubber-coated relays mounted to a bracket mounted to the driver side fender just behind the headlight.
    follow these wires to where they lead, and remove the entire setup - which should include the two relays, plus a ground wire, plus the wire to the smaller radiator fan (this fan can also be removed) and probably a couple other little things.
    this clump of wiring is self-contained and only relates to AC, so when you remove it, all it will leave in its place is a single 8-pin plug. leave this disconnected, because thats how cars without AC came, since AC was optional.
      that's the exact answer I wanted haha. Wow, I'll take a look at it on my lunch break. I know the two rubber relays you are referring to.
      Thanks a lot man, that'll clean it up a bit. Plus a coupleless wires to have to worry about haha
