camshaft lube? is it necessary?
    I just got my Cyl. Head back from the machine shop and they took off everything to hot tank it and stuff while doing the valve job, but should I put camshaft lube back on the cam when reinstalling it?
    And where can i get this lube anyway?
    Yes.
    wat?
      Originally posted by C91BLX7
      Yes.
      where do it get it from any auto parts store? checker autozone has it?
        Shouldn't be too hard to find, CarQuest most likely would have it.
        wat?
          I know it not really the same as a new head, but when i put a differnt cam in my old head, i just dumped a good amount of motor oil on the cam journals (Sp?).
            i've alway used it, if you go to honda ask for the moly-cote lube. its like 12 bucks for a tube of it.
            Finally Up and Running. Numbers to Follow. Check my MR
              Sounds like assembly lube, I bought some from an autozone type place once.
              I'm just curious what you've been driving during the cb's downtime?
                so this stuff works? i just ran to Autozone before they close so i can adjust my valves before putting on the cyl. head/intake mani on the car
                  A BEAUTIFUL 2003 Toyota Sienna Symphony ....sad to say, i think its faster than my CB7
                    The Sienna is the slowest vehicle on earth... right there with the Grand Marquis. Of course, that may just be the drivers...
                      I use TORCO assembly lube... Its the bomb... But if you soak the cams well with good NEW oil... it will be fine (if it is not a brand new cam). The cams actually absorb the oil into themselves... New cams should be broken in as per manufacture spec.
                      The Torco has a very high zinc/phosphorus content... This is a good thing
                      750 WHP/575 TQ CD5 Raping a street near you....
                      realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
                      GFI HOLLA!!!!!!
                      http://www.youtube.com/watch?v=Cdiz0k0Rudw
                        who sells that stuff? ^^^^^
                          not w/ a 210hp V6 and all the seats taken out That things hauls ass, but body roll is a bitch in it. Its got a limiter at 108 though lol. At least it has a good sound system....its called the Symphony since it has a JBL sound system which has decent bass
                            the idea of a dry cam spinning around in a dry journal makes me cringe... granted it would pressurize with oil, but that would be horrible for the engine.
                            slather that sucker in assembly lube for sure... you can find it at just about any auto parts store... i use Permatex UltraSlick.
