I did have a 4th gen accord at one time(well half of it). i'm not new to hondas in general. but i did come accross somthing rather annoying.
the engine i'm working with is a f22a6 from a 92 EX-R
if you look at the pic below, theres a small pin in the crank to line up the tq converter plate, i assume so you dont get the timing markings wrong.
the flywheel is from a 90 lx f22a1... i was told there should be a hole for that little pin to go in... but there isnt... i will line up the markings accordingly using the underpully..
SO.. i tried pulling it with pliers, vice grips, channel locks, bolt cutters etc.. it wont budge, so i stopped incase i will end up wrecking it.
can i just grind it off and call it a day?
i have a h22 flywheel still bolted to its block. do those have a hole that would match this?
thanks in advance.
thanks in advance.
