2 Door to 4 Door Disk Conversion
Originally posted by deevergoteThe Accord doesn't have one. If you don't use the valve, you'd need to swap over the brake booster and ABS components.
The prop valve in the pics, is that a kit that someone made that I can by somewhere, or do I need to find all the pieces myself? (it looks like a nicely done setup, to bad if no one sells it as a kit)
Does the prop valve need to come off of a specific year of integra??
I see twice as many accords then integra's in junkyards. Wondering how hard it is going to be to find.
Originally posted by AutoH22AccordSo the Accords have no kind of prop valve? or is it built into the master cylinder? One would think that it should have one somewhere. So your telling me that if I don't get the prop valve then I will need the brake booster from the accord that I take the brakes out of? No ABS on my year, so I won't need that. When your meaning brake booster you talking about Master cylinder? or just the brake booster? or both?
I see twice as many accords then integra's in junkyards. Wondering how hard it is going to be to find.wat?
rear disc accords all had ABS which incorporated proportioning, there was no actual separate valve. the non-ABS cars had a normal valve shaped like the above, except they all had rear drums... which would make the valve incorrect for your application.
we use the 4040 integra valve because its the same layout as the standard nonABS brake lines on the accord, except its proportioned for rear discs.
The pic displayed uptop of the prop valve, is that setup with pipes for an accord, or is that the ones from the teggy? IM going to be running steel braided lines to the prop valves, then down from the valves to the rear end with SS lines. Will this be sufficient enough for a DOT 4 conversion as well?90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by deevergoteThe valve is necessary for proper functioning of the rear brakes.
Originally posted by AutoH22AccordOkay, so I'm going to get the integra 40/40 prop valve cause I want the brakes to all work correctly. So what year of integra's would I find the 40/40 valve on? And are the 40/40's only on integra's with rear disk brakes?wat?
