Water Leaks when Raining..
    Does anyone have an idea of what can cause my car to leak on the diver side.. To be specific it's leaking from where the main relay is and I can't understand why. The floorboard is soaked!! I can't figure out why it's leaking or where EXACTLY it's coming from. Would anyone have a clue on where it's coming from and how I can stop it?! Thanks in advance
    Originally posted by Juice21
    thnx pimpette, your car inspired me to go lower
    Originally posted by GameChewer
    Shiit i heard that, you heard the queen!
    Check the seal around your windshield, as well as the weatherstripping on your door.
    If it really is coming from behind the dash, you'll need to pull the dash to find it. I've done that... and it's a pain in the butt!
    One way to find a leak is to clear the area where you think it's coming from, dust the area with baby powder, and then run a hose over the car until it leaks. You'll be able to easily trace the leak thanks to the baby powder, as long as you applied it to where the leak is coming from!
      Ya I've heard taking the dash off is a pain in the butt but I guess it'll have to be done! Here goes nothing lol..
        I think I'm missing the waterguard that goes to the inner wall of the door.. where the door and the fender come together when the door is shut, that lil rubber piece! The door had to be replaced and I think that door was off a 91 accord so it was missing that rubber piece. Is it hard to find that piece and take it off and put it on the door I have now or am I going to have to go to Honda and buy that piece or can it even but replaced at all?! Lemme ask that ahahaaaa get back to me when you can.. Thanks and I appreciate your response and help!
          happens to me all the time, it drips right from that clump under there. i traced it back up to the top of the dashboard, im pretty sure its coming in from the windshield trim. or that little rubber corner at the hinge of the hood on the cowl...
            Is it fixable?!
              use some silicone
              93 SE F22A6
                Originally posted by breeziebabyyy
                Is it fixable?!
                of course it is, everything is.
                just gotta find the source and plug it up.
                  i might look into this tomorrow when she brings it over for some work !!
                  Originally posted by Devergote
                  A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
