Integra clock=home clock
    This sounds prettttty dumb, but I have an Integra clock that I got from the junk yard, it fits my car fine, but there are weird white spots on it that I cant get off. I was wondering if there is a way to possible get it to power on to use just in my room? There are four prongs that connect to the factory harness ( G, D+, C+, L+) if that helps
    get a 12volt wall cube from radio shack, hook up the negative wire to G, and then the positive wire gets hooked up to two of the other pins. one is power so the clock remembers the time even when its off, another is power to turn the display on, and the other is power to dim it, as if you turned your headlights on. play with the other 3 pins until you find the two you need, leave the dimmer pin unused.
      http://www.circuitcity.com/ssm/Durac...oductDetail.do
      Duracell 12 volt battery
      I would love to create some sort of casing (possibly out of other CB7 parts) and make a nice table clock using that battery.
        to be honest i doubt that battery would run that clock very long... itd be great as a 12volt backup battery but not to have it on daily...
          G=Ground. D=Dimmer. C=Constant. L=Illumination.
            Yeah, I suppose so... Plus, I keep forgetting that I can plug in a table clock!
            I may do this next time I hit the junkyard. Probably with an old greenie.
            Hook it up to a stock Honda radio and make a clock radio! I've got two of those!
              Wow, I got more repsonses then I thought I would get. Probably going to run up to radio shack tomorrow
