my ground wire started to smoke and melt??
    i installed my deck and everything was working fine until a couple days later when i started up the car. the ground wired started melting?? i did everything correct, could it just be the deck?? cause when my friend had it he spill some juice on the face. could that be the cause of it?
    1994 Accord Coupe LX BPU
    1991 Galant VR4 #1395/2000 Sold
    1990 Accord EX 4DR Sold
    1990 Galant Base Model junked it
    1991 Accord EX 4DR gave away
    a ground wire is just as important as a power wire.
    if something draws and uses lots of current, it pulls it from the battery, but it has to get back somehow... through the ground wire to the chassis.
    a fuse is nothing more than a wire. when too much current goes thru it, it heats up and burns out.
    your ground wire acted as a fuse. for some reason it wasnt getting a good connection so a large amount of current was passing through a small wire. heat, and meltage.
    my suggestion for repair: redo your grounds! take them off, sand them clean, and use a new clean bolt.
      KUDOS KUDOS LOL I COULDINT OF HAD SAID IT ANY BETTER WOW.
        i was thinking that its the deck, cause it did the same to my dad's truck now it wont start up any more. i mean it does but it'll burn the fuse right away.
          chassis ground the deck. make sure everything is hooked up properly....what fuse is blowing?
          Retro!
          Hater
            Sounds like that deck is shorted internal.
              yeah thats what i think too. the deck probably got mess up when my friend spill some juice the face.
                Your ground wire might've been too small. try using some 4 guage wires.
                  it was just the stock ground wire that connect to the plug.
                    buy a new deck..
                    and use a better ground..
                    problem solved
                      honestly for a deck, it dont need a t hick wire.
                      Retro!
                      Hater
                        i'll probably get a new deck later on
                          what head unit do you have??
                            yup sounds like deck is internally shorted, I had an old Pioneer do that one time lol I redid my harness 3 times and still had the same problems, then hooked up a different pioneer (with the same plug) and it worked fine...
                            -Josh
                            91 Accord LX Sedan 5-speed (daily/project) - JDM H22A swap
                            91 Ford Ranger XLT Supercab 5-speed 2.3L (broke)
                              for a deck? rofl
                              wat?
