Brake Lamp Light Is On
    Hey Guys I was wondering What is wrong with my Brake Light Lamp. It Went on and off a few times over the summer And Not The light just stays on there solid. All my lights are working perfectly There is No Bulb that Has Been burned out. Just recently i replaced my Licence Plate Light Bulbs with Lumens Blue LED. Do You think its because of that?
    Either there is a break in the harness or the circuit is corroded. There may be other problems too.
    License plate bulbs do not trigger the dash warning light though.
      Oh Okay Alright But I Guess Its The circuit. i Wish I Knew Which side was the problem :S
        Clean all contacts in the bulb recesses and the wire harness and use dielectric grease when re-assembling.
          If you're referring to the main brake light indicator, (the one that lights up when the e-brake is pulled)...
          I'd check your brake fluid first...
          BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
          BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
          Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
          CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
            check your brake switch, the rubber part probably wore off. if thats what happened its literally a 2 cent fix (if you're referring to the brake lights) but if its the dash, check your brake fluid
            FRIENDS
            DONT LET
            FRIENDS
            ROLL ON
            ROTA'S
              I've had the brake/tail light indicator come on, and all my tail/brake lights were working, I bought a few new bulbs, and replaced them all at the same time, and the light has not been back since.
              On another note, there is a brown box in the tail lights that sometimes has issues, and replacing that brown box fixes it.
                Nope Its Just The Indication That Come On Right Under The picture of The car, Near The Trunk. Where It Says something like Brake Lamp indicator or something. Its Not the light when u pull ur E-brake. But okay ill try the dielectric Grease after but also ill check the rubber behind the pedal as well. Thanks guys
                  Yes Ill Check the brake switch, for some random reason i thought it was behind the pedal. Where is that brake switch located so I can check the rubber if its worn off or not ?
                    OK, if it is the indicator under the "little car" then check your third brake light. The one in the rear window...
                      I am haveing the same problem everything works fine but everytime i hit the brakes the light comes on and stays on
                        Check the brown box mentioned earlier, the sensing circuit may be bad.
                          Brake fluid level. Check that
                            will do thanks
                              Sometime it could be the cluster itself, I've swapped between two clusters before and the cluster that indicates brake lamp problems says that both car had lamp problems while all the brake lamps on both car worked just fine.
