ok i read that i need resisters for them. how many do i need per led?
help hooking up leds
Info might be in this sticky, if not... PM greencb7inkc.
http://www.cb7tuner.com/vbb/showthread.php?t=108559
Originally posted by Joshs92ex View PostInfo might be in this sticky, if not... PM greencb7inkc.
http://www.cb7tuner.com/vbb/showthread.php?t=108559Originally posted by charlie0882004 View Posti didnt find my answer
Originally posted by cvc7chris View Postjosh linked you to the thread that tells you how!!! lmao我愛我的本田
It was intential, if the info is in any sticky, it'd be in that one.
I didn't read it, had no need to... so I informed Charlie that if it wasn't in there, to PM the op (greencb7inkc).
most component (single) LEDs operate at something like 3.6 volts. You can use 1/4 or 1/2 watt resistors to step the car's 12-14.4 volts down to a safe 3.6 to keep from blowing the resistor the first time you turn on the power.
You would use one resistor, say (560 Ohms) per individual LED.
A lot of it has to do with how many LEDs and how you wire them.
You can use one resistor to four or more leds if you have the specs.
Check out how easy this link makes it:
http://led.linear1.org/led.wiz
If you are using prewired stuff, the resistor's already built in.
If your brake light out indicator exists and goes off, you can add load resistors which simulate the original bulb's resistance..or you can supposedly trick the sensor that sets off the indicator...it's in the taillight bulb assembly I think.
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
holy CRAP lots of misinformation in this thread... edit:except lucid's post. except many modern high-intensity LEDs run at 2.2v, not 3.6v - make sure you find out the voltage and required current for the LEDs you are using. then:
http://ledcalc.com/
check out that link, it lays it all out for you VERY clearly, including with a diagram. and it explains it in detail.
can also check out www.superbrightleds.com have plug in style leds that fit in perfect and have no issues....BRIGHT!!!!!!!Kyle C
2002 Accord Sedan EX - standard- daily status
1991 Accord Wagon LX - auto - 304K & slipping transmission
