OTHER chrome removal techniques?
    im trying to strip the chrome off of a grill i just got
    and its taking to long and i dont have anything to put it in
    or enough bleach
    SO
    is there any other way
    that works
    to get it off
    (besides sanding or bleach)
    haha
    thanks
    or enough bleach
    SO
    that works
    to get it off
    haha
    thanks
    you can try paint stripper? but be careful that stuff burns your skin on contact. It comes in a spray can. But Idk how harsh it is on the plastic, I've only used it on my aluminum intake plenum to get this paint off.
    But for mine I just used sandpaper, like 400 grit or 800 grit. It came right off after I did that for about 30 min.
    member's ride thread
    91 Accord SE 176k
      if you cut a chunk of the chrome plating off with a razor blade, you can peel it off with your fingers in pretty good sized pieces.....this is probably the fastest way really, except itll scrape up your fingers good because the plating has sharp edges.
        yup
          ill go see what i can do
            so the stripper i tried
            like melted and softened the plastic
            but didnt touch the chrome
            lol
              peeling is the easiest way to go hurts your fingers like hell but is not too time consuming
                it just dosnt want to come up
                even with a razor im still having problems
                  lol
                  lol, okay don't use that. Umm, yeah then i guess try just pulling the chrome trim off. I only used sandpaper once i had the bulk of it off. Well most of mine was already gone anyways.
                  just use sandpaper lol, it'll eventually get it off.
                  91 Accord SE 176k
                    I just sanded the surface until it wasn't shiny. Then I primed and painted over it.
                      yep, primed and painted mine too. I did two coats of prime just for nice even coverage and then 3 coats of black paint.
                      91 Accord SE 176k
