some bozo decided to run a shopping cart or someone backed into driver side lens and made a dent on front of driver fender. i'm not too worried about it but wanted to ask if the dry ice or air dust trick will work well or is this more of
dry ice or air dust dent removal. HELP!
depends entirely on what the dent looks like.
the dry ice will remove more heat from the panel, it is frozen c02 and is -170*f i think. the stuff in the air duster is liquid co2 (or liquid propane, or similar) and is not nearly as cold.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by XcluziveAZNCanned Air is not CO2 i think
according to wiki it's
"liquified difluoroethane, trifluoroethane, or tetrafluoroethane in a spray can"
I dont know what that mean Not a chem major.
difluroethane is 2 flourines on an ethane molecule tri is three and tetra is four!!!
but if you look at the side lens for the blinker the dent is right in the middle if it at the very front of the fender.its really thin about 1/2 - 3/4 inch from top to bottom and 2-3 inches long (from front of fender back)
It can be done if done properly. If not you can fuck it up. Doesnt hurt to try since its already fucked anyway. Get some heat on the fender around the area moving in a circular pattern and immediately put the dry ice on there. Thats the proper way to do it. Heat expands the molecules while the immediate cold makes them contract and eventually pop out.
Originally posted by NAiL05It can be done if done properly. If not you can fuck it up. Doesnt hurt to try since its already fucked anyway. Get some heat on the fender around the area moving in a circular pattern and immediately put the dry ice on there. Thats the proper way to do it. Heat expands the molecules while the immediate cold makes them contract and eventually pop out.
