Keyless Entry QUESTION!!
    Is it possible to buy and OEM keyless entry from a newer accord and install it in my cb7? Or would it be some type of big hassle, cause i have a 93 se and it came with a keyless entry but its old and doesn't work well. Someone please let me know. Thanks!!
    If you are going to spend the money, you might as well just get some sort of alarm system, with keyless entry.
      im figuring an OEM kit would be harder to install than an aftermarket one, as all the wires are preloomed into a harness and you wont have any of the pinouts, and itll all be custom wiring just like an aftermarket kit. and if u buy a kit/alarm youll have tons of extra features, colorcoded pinouts, and plenty of loose wire to work with, and itll probably be cheaper.
        Thanks alot i appreciate it!!!!
          just get a alarm that has keyless entry function and shaved your doors like i did on mine :P
