**Are you a CERTIFIED ELECTRICIAN?**
    Originally posted by That1guyN8
    Why wouldn't I want to use that box?
    What do you mean by "exposed"? Why would you want the wires exposed?
    if youre doing wiring in already finished walls, youre supposed to use "exposed" boxes... the blue ones he pictured are made to mount directly into a sheetrock face, you make the splice inside the box, and put a blank cover over it. its exposed, meaning you can still get to it by removing the cover.
    unless you want two eyesore blank plates (one on either side of the door), use the joist boxes like i pictured... you have a hole cut in the wall and have access to the studs, the wall is basically unfinished where youre working...
      Would this still work?
      I'll mount one on each side of the stud and I have a metal plate to cover it.
      Is it unsafe the way I'm doing it?
      Midwest car club
      Current rides:
      91 accord lx (5spd)
      92 accord lx (5spd)
      93 accord lx (auto )
        one on each side of the stud, meaning one on each side of the doorway, right?
        nothing unsafe at all about using that box.
          correct
          Midwest car club
          Current rides:
          91 accord lx (5spd)
          92 accord lx (5spd)
            Well it looks like I'll just stick with the metal boxes since I have them already and they'll still be safe.
            Thanks turboaccordlx for your input.
            Midwest car club
            Current rides:
            91 accord lx (5spd)
            92 accord lx (5spd)
              Its illegal and not safe to burry a junction
                then what about all of the junctions behind your walls that the electricians put in before the sheetrock went up?
                  he can use any box he wants as long as theres an exposed plate to access it in the future. simple. You cover it, its illegal. you have a fire you screwed isurance wise.
                    well turboaccordlx, I'm really glad you let me know that. I was actually going to do everything today, but now it looks like I need to put it on hold and get the right stuff.
                    So what your saying is, I need to mount it flush with the wall and just have a cover over it like a switch plate kind of deal, right?
                    Midwest car club
                    Current rides:
                    91 accord lx (5spd)
                    92 accord lx (5spd)
                      correct.
