If I have a 5 gallon compressor that will do 135 PSI max with 4.8 CFM at 40 PSI / 3.5 CFM at 90PSI, and a gun that will do 420ft-lb tq. but requires SCFM of 3.7 @ 90 PSI.....
Assuming I want to max the tool out, what is the maximum setting I can/should set the tool PSI on the tank for this setup? I had always used 90, thinking that the tank can only push max 90PSI at 3.5CFM for this tool but would setting it to 130PSI do anything here?
To summarize:
Tank:
135 PSI max
4.8CFM @ 40PSI
3.5CFM @ 90PSI
Impact Gun:
420ft-lb torque
needs 3.7 SCFM @ 90PSI
To summarize:
Tank:
135 PSI max
4.8CFM @ 40PSI
3.5CFM @ 90PSI
Impact Gun:
420ft-lb torque
