Anyone has a Windows 7 key gen I can have, use, borrow, whatever??
Windows 7 help!
With the help of my fellow cb7tuners im up and running
I played around with 8 and i wasnt impressed really.1993 Accord LX - Sold
93 BMW 525it - SOLD
92 Accord EX Sedan - SOLD
2000 Accord Coupe - Traded-In
2003 Accord V6 6spd Coupe - Sold
2001 Honda Civic Ex - SOLD
2013 Chevy Traverse LTZ - Kid hauler
2003 Acura Tl 3.2 - Daily Commuter
Originally posted by Gemini View PostWith the help of my fellow cb7tuners im up and running
Originally posted by Tippey764 View PostWas it my key that got you going or did that not work?1993 Accord LX - Sold
93 BMW 525it - SOLD
Originally posted by dj_ender View PostYou could have also used RemoveWAT 2.2 to remove the authentication process all together.
I have them both in a VM, and both seem to work well.
One simply says it's activated. The other used removeWAT.
Which would you use?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Always use the activated one, especially if it's "genuine". removeWAT works just fine, but you have to watch the Windows udates to make sure you don't install an update that detects the hack. Only use the removeWAT tool if you don't have a good serial key, and don't want to use a keygen.
And you are no longer a "genuine" Windows user, which basically just means you can't download anything from Windows.com.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by dj_ender View PostAlways use the activated one, especially if it's "genuine". removeWAT works just fine, but you have to watch the Windows udates to make sure you don't install an update that detects the hack. Only use the removeWAT tool if you don't have a good serial key, and don't want to use a keygen.
Interesting point about remove wat:
The version I used worked fine until I tried to install MSE. It detected it and wouldn't let me continue.
I did a bunch of updates and tried again. Bam. It worked.MRT
