ok, so obviously im trying to connect my f22 harness onto my H22. I got all the neccessary extra plugs (vtec pressure, solenoid, knock....).
Here are my Questions.
My H22 is JDM but already modded to work for USDM. So that means the fuel hose is on the left side (usdm) and not the drivers (jdm). So that means mines is correct. but when i put the wiring rail and bolt it up, the rail touches the Vavle Cover. I am pretty sure that this isnt supposed to be like that for obvious Reasons. Is there something i am supposed to do here that i missed or i didnt get while reading?
OK, now for the wirings. Im pretty sure that this pin plug is supposed to go here, but im not exactly sure how to connect it, since in the block its just a screw. Do i need to cut if a circle pin type thing so i can screw it in there?
I am not sure where these two plugs go. They would both be by the dizzy, but my dizzy is taken off, but i cannot see any plugs around there that need to be pluged.
Now in this picture, i have some where i think they are supposed to go. The orange one, i have no idea. The Blue one is i think the water temp sensor, which was broken off on my f22(ran fine the whole time)(should i just get another plug and solider it in?), The green one, is i dont know, but i know of my F22 there was a plug where the arrow is pointed, and i remember reading i about it(i think it was this plug, at least).
Now i know one of those rectangular ones are the VSS(I think). I also cannot find the reverse light plugs either, which i know is 2 pin plugs .
I need to get all these plugs straight first before i rip apart all the heat shrink and rewrap everything.
Sorry for the long ass post, and thanks for reponses.
