How can I tell if a jdm h22a is OBD1 or OBD2?
JDM H22a: Obd 1 or Obd 2?
92-96 obd1
97-01 obd2
some 96's may have come obd2.
if there is a black MAP sensor screwed to the top of the throttle body and only has a 4-pin distributor plug, its OBD2. no map sensor and a normal 8-pin dizzy plug indicates obd1.
FYI either motor can be used in a cb7, except if you have an obd2 version, you need obd1 injectors and distributor to "convert" the motor to obd1, then it goes in like normal.
Originally posted by cp[mike]92-96 obd1
97-01 obd2
like what cp[mike] said, but all H22's that came with the CD6 and BB1/4 were OBD1.. only 97+ were OBD2..
the H22a7 (euro-r/type-s) are OBD2..
OT: cp[mike], if its OBD2, y do we need to convert it back to OBD1??
Click sig to view MR thread
Links to other rides:
Honda Accord Euro-R
Honda Odyssey Absolute
Honda City I-DSi
Honda Stream
Well, my dizzy has the 8-pin connector, identical to the one on my f22a1. So that should indicate OBD1... My throttle body, however, has the black MAP sensor sitting squarely on top of it.
So, if my engine is OBD2 and somehow I have an OBD1 dizzy, then I'm a set of OBD1 injectors away from making it OBD1. But if my engine is OBD1 and somehow I have an OBD2 map sensor, then I would assume I should just use an OBD1 map sensor.
Is there another way to identify if its OBD1/2?
Originally posted by blizzard335OT: cp[mike], if its OBD2, y do we need to convert it back to OBD1??Last edited by cp[mike]; 03-28-2007, 08:27 PM.
owhh.. but if we took the whole harness from the half-cut, that wont be a problem, ryte? ECU's and all, convert the car to OBD2..
but now, i cant check my DTC's using the PGM tester, coz i didnt take the 13-pin connector.. i can only check by jumping the pins..
Honda Accord Euro-R
Honda City I-DSi
Honda Stream
Thats the easiest way to check for codes....Why convert to obd2 you lose the option to tune your car easier. Plus its more work than it looks like. Just use your harness modify the wiring. Everything is explained in the swap sticky on swapping the motors. Read it before asking anymore questions. IT also lists whats obd2 and how to do the obd2-1 conversion.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
