This is my first DIY thread. I've done lots of DIY projects, but never took any pictures. I'm a visual learner personally so I like lots of pictures. Anyway I hope this helps some people. I did a search and didn't find an offical DIY for this so here it goes...
I must credit cp[mike] for the original idea. Thanks man!
My JDM headlights came with all four headlight harnesses (two H4's and two H1's). If yours did not you can get them from SUV Lights.
Wiring JDM headlights to a USDM CB7
Disclaimer: I am not responsible if you injure yourself, others,
or the parts you are working on. Proceed at your own risk.
Tools/Parts Used
* Two 9005 male headlight sockets
* Two 9006 male headlight sockets
* Wire Stripper
* Electrical Tape
* Needle Nose Pliers
* Scissors
001
I ordered two 9005 and two 9006 male headlight sockets from SUV Lights. Here is a photo of
each one. The blue socket is 9005 and the white socket is 9006. Total cost: $28.00 shipped.
002
Separate the terminal pins with scissors or wire cutters.
003
Strip a small section of the wires coming from the JDM wire harness and place them into the
terminal pins as shown.
004
For this next part I used needle nose pliers but I would reccomend barell roll crimpers if you have
access to them. I just folded one side over the other. And then made sure they were down real
tight. Repeat this procedure with the other wires.
005
Next you'll insert the pins into the sockets. They should just snap right into place.
Note:
9005 (blue socket) goes to H1. This is the highbeam.
9006 (white socket) goes to H4. This is the lowbeam.
006
To finish it up I wrapped the exposed wires with electrical tape for protection and a cleaner look.
007
Finished product:
Enjoy! Hope this helps someone out there. Let me know what you guys think and/or anything that I should add or change.
Tools/Parts Used
* Wire Stripper
* Electrical Tape
* Scissors
001
002
003
004
005
Note:
006
007
Finished product:
