Current:
![](http://i1173.photobucket.com/albums/r599/DCB7/rr6.jpg)
Lower:
![](http://i1173.photobucket.com/albums/r599/DCB7/raw1.jpg)
![](http://i1326.photobucket.com/albums/u659/DCB72/WAX/wax3b_zpscda0c924.jpg)
ENGINE
F22A1
F22a6 runners, H23 Plenum&Throttle body
(smoothed and mild polish inner manifold)
EGR, FiTV and boost valve delete
Billet Aluminum block off plates
Cruise control delete
Spectre air filter X
3" Short Ram Intake
NGK plug wires
NGK Vpower plugs
(Custom painted valve cover)
Maintenance
Oe replacement Distributor X
OEM Distributor w/new ignitor, inner&outer seals
Felpro vc gasket, upper&lower seals
Denso O2 sensor
Oe replacement radiator
Injector seals
EXHAUST
4-2-1 Stainless header
Universal resonator
2.25" axle back piping
EXTERIOR
OEM Rosewood paint
OEM 93 lip X
Legend Sedan Lip(custom)
OEM 93 rear mudflaps
INTERIOR
Tints
Brass shift knob X
Stock shift knob (Custom)
Faux leather shift boot
Acura CL headrests X
DA headrests
Blue LED cluster lights
SUSPENSION
Spec-D Lowering springs X
Tein S-Tech Lowering springs
Front camber kit X
Front upper control arms
KYB Exel-g front struts
Forza front strut bar
Polyurethane End links
CV axles
BRAKES
97 Acura CL 3.0 front calipers
93 CB9 drilled/slotted front rotors
93 CB7 EX rear disc conversion
Premium rear rotors & ceramic pads
WHEELS
17x7.5 Azul Alloys
205/40r17 Nexen n3000(f), n5000(r)
AUDIO/ELECTRONICS
Sony head unit
SSL 200watt Sub-amp
10inch Xplod subwoofer w/bazooka style enclosure
Pioneer 6inch 2way speakers
Tweeters in rear w/built in crossover
Viper alarm
FUTURE PLANS
yep
![TU](http://www.cb7tuner.com/thumbsup.gif)
When I got it(133K miles).
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3747_zps063c7754.jpg)
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3741_zpsad7fb790.jpg)
Added 93 OEM lip
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3740_zps8b3ba784.jpg)
Added resonator, tints, and end links + OEM o-ring from dealer(still leaking)
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3779_zps509b324f.jpg)
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3778_zps633aa821.jpg)
Then added lowering springs + camber kit, and new CV joints
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3782_zpse920bbd4.jpg)
Put wider wheels on
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3790_zpsc555f9c1.jpg)
Added OEM 93 rear mudflaps
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3797_zps14cd3f2d.jpg)
and stainless tip
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3795b_zpsd63c7645.jpg)
Changed front upper control arms
![](http://i1326.photobucket.com/albums/u659/DCB72/101_4132_zpsfd814e6c.jpg)
Replaced leaky distributor
![](http://i1326.photobucket.com/albums/u659/DCB72/112_0153_zpse847dbf1.jpg)
![](http://i1326.photobucket.com/albums/u659/DCB72/112_0158_zps3b3f337f.jpg)
thats it so far. I'll post updates on modifications as i go along.
(Updates and pics on every page)
Thanks for looking
![thumbs up](http://www.cb7tuner.com/thumbup.gif)
![](http://i1326.photobucket.com/albums/u659/DCB72/101_3794_zps5e6ecf05.jpg)
