I would like to build a Traction Control System
    First off, I'm pretty sure what I want to build Is a traction control system. But it might be a "Stability System". Since I am unsure of the difference, I will use them interchangeably.
    Anyway, My goal is to fix my abs(hopefully a sensor) and put an additional computer in my car to interface with my abs computers and sensors. This additional computer will work in harmony with my abs to provide additional stopping power. Think newer cars have abs AND Traction. Since Our cars only have abs, I want to engineer the additional piece. Anywho, the abs releases the brakes, which I am fairly sure is the basis for traction control. My additional computer will monitor the speed sensors (maybe gyros later on) and make its own decisions to apply the brakes.
    So, I need help with finding interfaces to the abs and speed sensors. Has anybody done this before? Any information regarding abs/traction control would be greatly appreciated!
    P.s. I know most of you hate abs and it breaks all the time. I want to do this partially to make my car safer and possibly add it to my resume later on.
    MRT
    sneaky motherfucker
      Yep, I'm that amazing. I asked this question on yahoo answers awhile ago, but didn't get any help. That's actually the reason I joined this site.
      http://answers.yahoo.com/question/in...6100015AAJWcFg
      If anybody wants me to describe it(this project) in more detail, let me know
      MRT
      sneaky motherfucker
        Also, its a 93 Honda accord. 10th anniversary edition. I just recently bled the brakes and replaced the master cylinder. I sucked out the abs fluid(I had extra brake fluid) and replaced the fluid. Since them my abs light, which always came on right away, has decided to come on at higher speeds. Sometimes I can get it up to 80 before it comes on. Any ideas on fixing it?
        MRT
        sneaky motherfucker
          I wish I could help, I just never thought about doing tcs in my accord. Good luck
            Thanks anyway. Do you know of anybody making their own tcs?
            MRT
            sneaky motherfucker
              I got nothing man, keep looking!
                All i can say is, it would involve more sensors and solinoids in your tranny and reprogram your computer, or add an electronic control mechanism, the other option would be to install an lsd tranny eather 5spd or auto, or you can install an lsd diff for drag racing i have come across some of these they range around $1500. LSD would be your best bet so when your wheel wants to start spinning your differential will apply an even load to both wheels
                Originally posted by Gummiegorilla
                Damn CBs are like a Rubix Cube sometimes !!!!
                  I was thinking mostly electronic control mechanism, Ie additional computer interacting and controlling the abs computers. I think that modifying the trans in the way your thinking of would fall more into the "Stability systems" distributing power to prevent burnouts. It would be helpful with a limited slip diff, but I was looking for more in the way of stopping power.
                  MRT
                  sneaky motherfucker
                    No offense... but even IF you do build a traction control system, it will PROBABLY function only if you try to drive on ice or drive like a maniac in heavy rain. I mean how often do you get wheel spin when driving a stock Accord (clutch dumps don't count)?
                      Its an automatic...
                      This was inspired when driving in a blizzard last year. I drove to a town an hour away, the whole time keeping enormous distances between me and the car in front of me. After I got there (and let the stress of sliding into the cars around me die down) my buddy and I hopped into his 03ish grand prix. He purposely slammed on the brakes at every intersection and gunned it whenever he could. That incident combined with others where I almost hit things due to me sliding, made me want to build this.
                      MRT
                      sneaky motherfucker
                        Idk man. I think it is going to take a lot more then just some sensors.
                        Where are you intending to aquire a computer from?
                        You have to take into account the many systems that tcs effect or communicate with to do their job appropriately, not to mention safely.
                        Systems like that that are found in cars like Audis for example monitor 1000s of processes hundres of times a minute.
                        Good luck though I will be following your progress. This would be the first of its kind for our platform.
                          Motec and some others have TC abilities. Search Honda EMS's
                          750 WHP/575 TQ CD5 Raping a street near you....
                          realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
                          GFI HOLLA!!!!!!
                          http://www.youtube.com/watch?v=Cdiz0k0Rudw
                            snow tires or learn how to drive? you'd have a better chance building a awd setup from a CRV
                            I <3 G60.
                              GEOFF you need to come up with a way where the tranny can drive one wheel at a time that is what traction control does i remember in my old saturn when i would stomp on the gas in the rain the wheels would alternate spinning every half second
