so i bought my cb7 with a f22b2 already in it but i have a problem with the driver side motor mount. the motor had the mount for the cb7 on it with only one bolt in, supposed to have two. not safe and mount broke anyways. so after that i got the mount for the 94-97 accord that the f22b2 comes in. it obviously bolted up to the motor but didnt fit in the mount bracket. so we grinded down the side of mount to make it fit and got it in and bolts lined up fine too. started up the car and noticed a loud grinding noise. so the crank was grinding on the wheel well. the we cut a whole in the wheel well and thats where its at know. runs fine i guess, except for when it pulls it goes to left and when i shift it goes to the right, i dont know if this is the reason but w/e. motor has a gangster lean and i want to fix it.
options:
1) get longer bolts and put washers between mount and motor? i was told its not safe.
2) drill a hole in the bracket to make mount sit lower? maybe?
3) yall tell me.
heres pics:
options:
3) yall tell me.
heres pics:
