Okay first i'm a noob to bodywork, anyway i'm removing my grill and i can get 5 screws out but the grill is being held on by 2 and i cant get to them without removing the radiator. how can i get the grill off?
grill removal
grill removal
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.Tags: None
there are only 5 screws, the other two are little clips. they have a tiny tongue sticking forward, you push this downward with a flat head screwdriver and they will pop right out. you might be able to get them from the front, but usually there are oblong holes in the top of the grille, to get to them from above. they stay attached to the headlights, once the grille is out, remove the two clips from the lights and reinstall them back onto the corners of the grille.
thanks worked perfectly
Originally posted by cp[mike] View Postthere are only 5 screws, the other two are little clips. they have a tiny tongue sticking forward, you push this downward with a flat head screwdriver and they will pop right out. you might be able to get them from the front, but usually there are oblong holes in the top of the grille, to get to them from above. they stay attached to the headlights, once the grille is out, remove the two clips from the lights and reinstall them back onto the corners of the grille.
is that what u push? im scared cas i dont want to damage the actual grill
sorry bout replying on an old thread
thanks for the help┌∩┐(◣_◢)┌∩┐
Originally posted by rave93 View Posti see the ovals but there is like a little knob inside them
thanks for the help
No need to apologize, you're one of the few "newcomers" who actually use the search button.
Originally posted by rave93 View Posthaha thanks?
um but there is no other way to do it right?
i was planning on cutting near the bottom but my dad said it will reduce the value of the car because it has been tampered with.
so yeh thanks again guys
haha JP. a new grill at a picknpull is like... 6$ ?? if you can find one. honda's get torn to shreds at my yards
Originally posted by Lokheed View PostUmm, you can find a new stock grill at a wrecker pretty easily. I wouldn't pay any less on a car because some guy cut up his grill. I wouldn't worry about that as much as guys not doing regular oil changes and general maintenance; now those things really destroy the value of a car!
Looks good now
