Well when i put in my new cluster, i took out all the bulbs that light up the gauges, and took off the little blue covers over the bulbs. Took out the two bulbs that light the whole cluster up and BAM, green reverse gauges looks perdy. And no ugly ricey looking silver/white etc gauges in the day
INT: Simple Cluster Mod
Yea I replaced mine with red bulbs and used led's for the ones that illuminate the cluster. Do you have any pictures?
Here is a pic of mine
No more cb7, 7 years of ownership and 196K on the ticker before she was sold
Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
NREMT-B | 300D and some glass
Originally posted by 91accord4door
but that looks even better.
Originally posted by timmy0tool
mike is your CEL on? or is that the battery light? i can't remember. is the H22 ok? the blue looks hot though!
there are two small bulbs above the cluster, that light up the front of the faces and the needles. if u turn on ur lights and look up from under the cluster (while its in the car) youll see them. if you pull them out, the gauges will only have their backlights, so the numbers will all light up, but only from the back- so they will look like reverse glow gauges. i believe this is what 97lude was talking about.
there are also three size 194 (for the two big gauges) and two size 74 (for the temp and gas gauges) that are in the back of the cluster. if you pull THOSE out, the numbers on ur gauges wont light up at all.
all of the bulbs are accessible from the back/top of the cluster once it is pulled out of the dashboard. you dont need to disassemble the cluster to get to any of them.
Geee wonder where you could have gotten that idea from??????
http://www.geocities.com/hondalover11279/Indiglo.html
I only posted this ALL OVER about a year ago.Last edited by 4thgenaccord; 08-31-2004, 04:45 AM.!!!!!!!!!!!!!!!!!!!
