on the way to 30 posts......cluster pics
actually, they arent painted
if you pop out the cluster, there are 2 light bulbs on the top of it and they lit up the needles.
I changed the bulbs for red ones, and tinted the transparent plastic, between the lights and the gauges, with crimson red glass paint
then put in 3 blue tripleLEDs194 bulbs behind it, to lit up the gauges and smaller ones (dont remember the number at this time )for the flashers/the oil temp gauge and the Gaz gauge. There also one to lit up the ring aroung the cig *litter?*
*by the way, I'm not sure about the word bulb....am I using it correctly)?? not much sure bout 'lit up' ......anyway....
my old dash...
[img]http://www.****.com/www/93lx/new-blue-dash.jpg[/img]
Originally posted by 90cb7beastdamn 418 ur car is running uber hot
The temp needle as been at the top eversince I changed my oil sensor (maybe I should have paid for an HONda one...instead of a cheap one.... and the oil light is on......
but everything works well.........so ......i'm ok with it for now
*by the way, I'm not sure about the word bulb....am I using it correctly)?? not much sure bout 'lit up' ......anyway....My Ride17.34 @ 78mph with 260k on her
bulbs that light the needles (and the tmep and fuel) are 74. backlights are 194. you can buy them both at superbrightleds.com
