had my car towed to the shop and...
    i found this puddle where my car was sitting should i be conserned with this leaking the way it should or for the amount of time it sat in my driveway not worry about it the car sat in my driveway for 3 weeks
    Every leak is a bad leak. It doesnt look like to much, but I would still see where its coming from and get it fixed.
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      i think u should get that checked out
        It's just like 6 drops. It's not the end of the world. You've just got a very small leak somewhere.
        Member's Ride Thread
        Originally posted by mercyboy
        I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
          somethings definitely leaking... it could be multiple places leaking, or it could be one thing higher up on the engine and after enough time the oil made its way down and is dripping from multiple places.
          i wouldnt say its critical, just always make sure you have enough oil, and try to visually inspect the motor to see where its actually coming from. could be 4 sides of just the oil pan, u know?
            Clean the bottom of your engine as well as you can with degreaser (don't get it on paint, and don't get it in your eyes). With a clean engine, you should be able to locate the source of the leak much more easily.
              thank you much for all the advice ill do the degreasing in the morning and track down the leak thank you all
                take to shop,have them to put the car up on the hoist with the engine running and walk under the car with a light and find out where the leak coming from.
