1992 Accord DX Sedan - BASE
Manual windows/doors, No AC
![](http://photos-045.ll.facebook.com/photos-ll-sf2p/v150/198/21/583512045/n583512045_434449_6705.jpg)
Quarter Mile times:
13.0 @ 112mph [1.87 60 foot]
Current time as of 11.04.07
Dyno Results:
402whp / 325wtq @ 20psi
![](http://i141.photobucket.com/albums/r66/colin_edge/finaldynopic.jpg)
Basics:
Heat delete
Emissions delete
P/S delete
IABs delete
No AC/Cruise factory
Engine Cylinder head:
F22A6 head
Resurfaced and cleaned
Delta 272 cam
KMS valve springs
KMS Titanium valve retainers
New OEM Honda valve seals
NGK 8 series spark plugs .020 gap
Engine Block:
F22A6 block
New OEM bearings/rings
ARP Head studs
OEM Honda headgasket
Unorthodox Racing Ultra S crank pulley
Air Induction/Fuel:
H23 upper/lower intake
H23 throttle body
RC 750cc injectors
Walbro 255lph fuel pump
Spoolin' Performance oil catch tank
Golden Eagle vacuum manifold
Generic breather filter
Cooling:
Custom mounted Aluminum Half-Size Del Sol dual-core radiator
Fail Safe 170* thermostat
One 12" slim electric fan
Turbo Kit:
Holset HX35 turbocharger
Custom tubular equal-length turbo manifold
Custom 2.5" aluminum charge pipes [hot and cold]
Stealthmode Oil line kit
Silicone couplers / T-bolt clamps
Precision 600hp FMIC 31.5x8x3.5
MRX chipped P75 - SOHC_Mshue Crome tuned
GReddy Profec-B Spec2 electronic boost controller
GReddy Type RS blow off valve
Tial 44mm external wastegate, custom location, custom dumptube
Exhaust:
Under construction (haha)
Transmission:
F22A6 5spd transmission
Competition Clutch Stage 4 clutch kit
Competition Clutch 12lb Flywheel
Welded stock differential
Exterior:
"Sponsor" Decals
35% window tint
Ventshade window guards
Custom mounted Taylor 4 post NHRA legal kill switch (will be moved)
Interior:
GUTTED!
Autometer Boost Gauge
Autometer Water Temp Gauge
Custom Roll bar
Kirkey alum. race seat
G-Force 5pt SFI approved harness set
Summit Racing battery relocation kit (RR trunk)
Suspension:
D2 full Coilovers
Collective Racing custom traction bar (broken and then repaired)
eBay strut bars [F & R]
Suspension Techniques sway bars [F & R]
94A Urethane engine mounts [Left, Right, Rear]
Brakes:
Rotor over Hub conversion
-Brembo Blank 2.3CL Rotors [F]
-Axxis Ultimate brake pads [F]
-OEM 2.3CL hubs
-OEM Accord wheel bearings
Rear disc brake conversion
-Brembo Blank Accord Rotors [R]
-Axxis Ultimate brake pads [R]
Goodridge Stainless steel brake lines [6 line kit]
Integra 4040 Proportioning Valve
Wheels/Tires:
ARP Extended studs [F & R]
H&R 5mm wheel spacers [F]
96 spec ITR wheels [re-powdercoated]
225/50R15 Kumho AST tires
American Racing Split wheels, 15x7, +40mm offset (?)
Mickey Thompson ET Drag 24.5x8x15 slicks
Quarter Mile times:
Dyno Results:
Basics:
Heat delete
Emissions delete
P/S delete
IABs delete
F22A6 head
Delta 272 cam
KMS valve springs
Engine Block:
F22A6 block
ARP Head studs
Air Induction/Fuel:
H23 throttle body
RC 750cc injectors
Cooling:
Turbo Kit:
Exhaust:
Transmission:
Exterior:
"Sponsor" Decals
35% window tint
Interior:
GUTTED!
Custom Roll bar
Suspension:
D2 full Coilovers
Brakes:
-OEM 2.3CL hubs
Wheels/Tires:
