INT: Removal of Door Panels (manual windows)
    well, it's fairly easy to take off the door panel on a cb7 with power windows and locks, but for us poor poeple with manual windows and locks, it's a bit tricky.
    tools required:
    - screw driver
    - patience
    1. remove all the screws:
    2. pull out the handle thingy:
    3. unhook the handle from the metal shaft (this can be a bit tricky).
    CB7 + H22A4 + M2S4 + JDM P13
    www.vancouveraccords.com
    4. (this is where it gets tricky) pull out the window handle as far as you can. there is a clip behind the handle that you will need to take off. try using a screw driver or something thin because your fingers will not fit. once the clip is off, pull the handle off.
    -you can kinda see the clip in this pic:
    -this is what the clip looks like:
    5. take off the speaker cover by pulling on the edges and sliding it down (it should pop off)
    6. pull on the edges of the panel to pop the rest of the clips out, then slide the panel upwards.
    and it should look like this:
    then you can change your speakers, install alarm actuators, or whatever
      hmm, is urs a 90/91? cuz on my 93, the speaker grille doesnt get removed, it is screwed into the door panel. just letting anyone know that theirs might be the same way.
        same here
        -Chris
        HondaSociety SN: HondaAdict
        -1992 Honda Accord EX (Wrecked)
        -1991 Toyota MR2 Non-Turbo (New Ride)
          hmmm, nope, mine's a 92.
          my speaker cover is not attached to the panel.
            i have a 93 too..cant find a way to remove a blown speakr
            MY 1n2 CB7
              good write-up..im glad i found this..
