EXT: JDM/OEM Intersection Lights (Cornering Lights)
    Got this from the Accessories Installation section at work.
    Hope this can help some of you guys...
    Even if its for a 5th Gen, the same principle can be used.
    I will upload the pics when i get home...
    Page 1
    Page 2
    Page 3
    Page 4
    Page 5
    Page 6
    Page 7
    gotta login to see them. save em and rehost them... if u need a host email all the pics to me at ****leet@gmail.com and ill edit ur post and post em up
      Ok i edited my first post...
      This should be of great help to people that buy the lights
      without instructions.
        Hey, this is cool. I plugged 08V34-SV4-100 into both Majestic's and San Leandro's sites and found the lights (um, like $200) and wiring harness (about $50/$60).
        That Control Unit looks mighty important ... that actually answers some questions raised in a thread a week or so ago I think.
          This is the proper way to set it up.
          I know people hook them up to the parking lights.
          But like it says in the directions....
            anyone made teh harness diagram yet?
            welcome to the DOHC-side..muuuahahahahahah
            http://www.cb7tuner.com/vbb/showthread.php?t=1906
              damn they have been discontinued...SHIT. I just want the fucking harness.
              Henry R
              Koni/Neuspeed
              1992 Accord LX R.I.P
              1993 Accord EX OG since 'o3
              Legend FSM
                Any ideas on how to make a complete harness for this?
                Henry R
                Koni/Neuspeed
                Legend FSM
                  yea there is another thread about it using the maxima relay and it worked fine for me until i got the OEM harness
                    PM'ed
                    Henry R
                    Koni/Neuspeed
                    Legend FSM
                      whats up with the pics???
                      93 Accord LX Sedan (sold)
                        They work fine for me!
                          work for me too
                            PM'ed
                            Here is a pic of the Maxima box. They are located on the driver side under the hood. They say CONT. CORNER on them. Be sure to get the pigtail too.
                            Here is the diagram that I came up with:
                            -Red/white - 12v ~ fused 15A
                            -Black- ground
                            -Red/yellow - low beam headlight lead
                            -Orange - high beam headlight lead
                            -Orange/blue - left intersection light
                            -Green/yellow- left turn signal lead
                            -Orange/black - right intersection light
                            -Green/red- right turn signal lead
                            1- Wire the red/white lead to the battery or fuse box with an in-ine fuse rated at 15A.
                            2- The red/yellow lead will tap into the Low Beam.
                            3- The solid orange lead will tap into the High Beam.
                            4- Run 2 wires to the left front and tap into the left turn signal with one and the other to your intersection light. The intersection light ground to ground.
                            5- The wire going to the left intersection light should be the orange/blue from the pigtail. The one going to the left turn signal goes with the green/yellow.
                            6- Run 2 wires to the right front and tap into the right turn signal with one and the other to your intersection light. The intersection light ground to ground.
                            8- The wire going to the right intersection light should be the orange/black from the pigtail. The one going to the left turn signal goes with the green/red.
                            This box allows the intersections to stay lit approx. 2 seconds after turn signals are off.
                            Here is a demo:
                            Hope this helps.
                              nice write up guys
