Accord F22 Removal Instructions
Written by: Patrick Hayden (ACCLUDE91)
Updated by: Mike Maset (cpmike)
![](http://www.m1xe.com/pics/f22/1%20copy.jpg)
This was done on a 90/91 manual - the process differs a little bit for 92/93 and automatics, but it is a great guide to base your work off of. some of the steps arent quite completed and its missing a few photos, but I will try to get that updated as my schedule permits, but you should still have no problems with what is posted here. full credit goes to ACCLUDE91 for this guide! he sent me a preliminary guide he was working on many years ago, and it was so useful in guiding me with my first engine swap that I had to host & post it for him, since he never got to 'finish' it. Thanks again for this one, Pat.
Originally written by ACCLUDE91:
Needless to say, this where everything gets disconnected from the motor, but also seems to be the part that all other swap articles include no information on. A tricky part that may need to be done by a professional shop is removing the spindle nut on the axles. You can get it, but it's a pain to do. As you remove the plugs, bolts, and hoses, LABEL WHAT THEY GO TO! Even if you know what it goes to by memory, it makes it so much easier when puttin it all back together! Use as much detail as you can fit on that label. If you're not sure what the unit is called that they go to, then pick a description of that item that will make you remember what it goes to. Remember the more descriptive it is, the easier it is later. I used masking tape and a black permanent marker to label them and you can tape all the screws from one unit together so there's no question what they go to. Please follow this step cause it gets kinda confusing once everything's out of the car and scattered all over the place. The more labeling and organizing you do at this point in the project will make the rest go smoother and quicker. TRUST ME ON THIS ONE!!!
To give more room and for ease of picture taking, I removed the hood. There are two 10mm bolts on each side to disconnect it from the brackets. You need to disconnect the windsheild washer fluid hose on the drivers side. Set the hood off to the side in a safe place.
From this point on, starting with the radiator fluid removal listed below, the car will not be driveable. Make sure you have it set up in a spot that has plenty of working room available where nothings gonna get messed up.
The radiator fluid needs to be drained. Put a pan under the drain plug on the radiator to collect the fluid and remove the plug. Allow it to drain. Next, start the car and run it for about 10 to 20 seconds or so....just long enough for the water pump to flush the remaining amount out of the system. Turn the car off once the majority of it is out. Make sure you do not run the car too long cause once the metal gets hot, it needs the coolant to keep it from warping and causing damage. Make sure to dispose of the fluid properly.
