is there any part that you have to use the f23 or f22 part? or am I able to mix and match everything? such as bolts ect... I have found that I have to use the f22a timing belt due to the f23 having a smaller cam gear? someone told me something about a bolt that has to be one of the other or it strips out if its the wrong bolt? did you bore the head out to match the combustion chamber, or just mate the head to the block as is?
PM me if you would like.
I appreciate it.
I appreciate it.
