Lol its all good. There are some screws in both rear wheel wells. When you remove those you can actually pull back the corners of the bumpers. There should be a couple of screws or bolts holding it on from underneath, you know where the tailpipe comes out and shit. 20 year old car, sometimes those are missing but they are supposed to be there. Then the fun part, removing all of those bitch ass plastic pins that run along the top inside of the bumper. You will be able to see them when you open the trunk lid. I believe you also have to remove the small metal thing underneath the outer taillights in order to get to a couple of them plastic clips pin things. That metal thing is held in by 2 10mm bolts that you have to get to from inside the trunk behind the plastic paneling. Be prepared to get some more of the plastic clips when re-installing the bumper because you will probably break a lot if not all of them trying to get them out. Lemme know whats up my nigg.
