Visitor Messages
    Im in the process of doing the k24 swap the motor is in i ordered the axles and wire sub harness from hasport already. What im asking is there a way you can let me know what situation im going to run into while im doing this swap such as fuel lines clutch lines are these going to be custom lines or what im also in the process of doing three other projects so money is a little tight but not to where i cant get this done any advice or info on where to source parts would be greatly appreciated also thanx in advance.
    what shall not
    kill you shall
    only make you
    STRONGER
