June 2013 AoM Nominations
This topic is closed.
    June 2013 AOM Nominations
    As the Accord of the Year for 2012, CB7H22Los, as well as past 2013 winners, are not eligible for AoM nomination in 2013. The other AoM winners from 2012 ARE allowed to be nominated. However, as they have already won the competition once, it is not recommended that they are nominated again. Let's get some new CBs recognized!
    Check out the Rules & Regulations - invalid nominations WILL be deleted!
    Please observe the format for nomination displayed here.
    Members must have 50 posts in order to nominate someone.
    Duplicate nominations will be deleted.
    Posts made that are not nominations will be deleted.
    Invalid nominations will be deleted.
    There is no need to second a nomination! If a nomination is valid, it will proceed to the voting stage automatically.
    Please only post ONE picture with your nomination. More pictures can be seen in the Member's Rides thread you link to!
    When nominating, please leave out any FUTURE PLANS sections. If it is not on the car, it should not be considered in the decision.
    Nominations will be Accepted until the 15th, but Voting starts the 11th, so be Timely in your Submissions.
    '94 JDM H22A: 178whp 146wtq
    If you say double dutch rudder, i'm banning you...
    I would like to nominate NWaccord's 92 LX. It looks good, baddest one I've seen recently in terms of performance. I think it is an efficient beast and a quality build
    Originally posted by NWaccord View Post
    92 LX
    ENGINE "New Setup"
    F22A1 Block-F22B DOHC
    Bore x Stroke: 86mm x 95mm
    Displacement: 2207cc
    Valve Configuration: DOHC 16 valves
    Compression ratio: 9.1
    Max power: 643whp
    Rev Cut: 8200rpm
    BISIMOTO 2.4 Turbo Cams
    BISIMOTO F22B/F20A Valve Train
    BISIMOTO Arias 86mm 9:1 Forged Pistons
    BISIMOTO Long Ratio Rods
    BISIMOTO 86mm Headgasket
    BISIMOTO Cam Gears
    OEM H23 valves
    OEM H23 valve stem seals
    OEM Bearings
    OEM main bolts
    OEM GSR Timing Belt
    OEM F22a WaterPump
    OEM F22a OilPump
    Precision 6262 Turbo T3/t4 .82 A/R
    Injector Dynamics 1000cc fuel injectors
    Aeromotive 340LPH fuel pump
    Koyorad R-series radiator
    ARP rod bolts
    Hondata intake manifold gasket
    KS Balance Shaft Eliminator Kit
    KS custom turbo manifold
    KS 2 1/2" to 3" downpipe+dump
    M2J5 Tranny Synchrotech LSD
    Competition Stage 4 Clutch
    7lbs Findanza Flywheel
    ESP Mounts
    ESP slim alternator bracket
    Garrett t3/t4 60 trim 82 A/R
    Greddy RS BOV
    Tial 38mm WG
    Hondata 4 bar map sensor
    Precision 780cc injectors
    Gutted Intake Manifold + Runners
    ARP Headstuds
    3" Mandrel Custom Exhaust
    Badlandz Electronic CutOut
    Cusco Catch Can
    AEM dryflow filter
    AC Delete
    PS Delete
    Chipped p28
    eCtune software
    Tuned @ KiazenSpeed by Ried (310whp, 294wtq@13.5psi on 2.5" exhaust)
    Tuned @ KiazenSpeed by Ried (505whp, 486wtq@20.5psi)
    Tuned @ KaizenSpeed by Ried (534whp, 448wtq@21 psi with new turbo)
    Tuned @ KaizenSpeed by Ried (643whp, 529wtq@30psi with new turbo)
    EXTERIOR
    Fresh Frost white paint job December 08'
    Full body work
    94 legend coupe lip
    Usdm Black Housed Headlights
    Jdm Side Markers
    Avs window visors
    Oem mud guards
    Sedan trunk+light conversion
    5% tint all around
    TAS Front Grille
    INTERIOR
    Stock!
    Type R replica steering wheel
    NRG quick release
    Garrett 30psi boos gauge
    In cab manual boost controller
    SUSPENSION/WHEELS
    Rota RB 16x7 + 22
    Dunlop StarSpecs 205/50
    BlackWorks SS Full coil overs
    TAS BIG Brake Kit V6 wagon
    AUDIO/ELECTRONICS
    Oldschool Panasonic Deck
    Unknown Brand 6x9
      Interesting... I'd like to nominate DJ Hizzle...this CB is simply awesome, has been through a lot more than deserves the recognition!
      http://www.cb7tuner.com/vbb/showthread.php?t=176995
      Engine:
      Stock F22A1
      CB7 EX Muffler w/Custom Tips
      K&N Drop-in Filter
      Removed Bumper Air Box
      Exterior/Lighting:
      USDM Blackhoused Head Lights
      DDM Tuning HIDs 55w 6000k
      DDM LED License Plate Lights
      Amber Corner Lights
      91 Acura Legend Coupe Front Lip
      Footwork:
      F2 Type One Coil Overs
      XXR 006 Gun Metal 17"x8" Front - 17"x9" Rear
      Adjustable Anchor Bolts
      Modified A-Arms
      Interior/Audio/Electronics:
      Pioneer Double Din DVD
      6 1/2" Alpine Front Woofers
      6 1/2" Alpine Rear Woofer
      Alpine Tweeters Front & Rear
      Pioneer 4 Channel Amp
      Modified Rear Seat: Sub Box Arm Rest
      All LED Lighting
      C-Pillar Interior Lights (Not Installed)
      Head Rest Monitors (Not Installed)
      Still hustlin that Old Skool.......it never ends.
      vv My Member's Ride Thread vv
      http://www.cb7tuner.com/vbb/showthread.php?t=123371
        NWAccord has declined the nomination for June AoM. You are more than welcome to submit another.
          hmm, ok. thanks
            hmm, ok. thanks
            Thanks Bro, I appreciate the Nominee DCB7
            The LX has one its AOM before, But I feel as other CB's should be recognized. There's a lot of badass CB's just waiting to shine!
            Once we hit 10sec pass then it will be ready for another nominee
            MRT H22A - 302whp - N2O
            MRT F22B - 643whp - 529tq @ 30psi
            11.33 @ 131mph @ 27psi
              Aight! no problem man.
              Very noble of you, till next time
                I would like to nominate Vex's 93 Accord EX ( if he doesn't mind). I really like DJ Hizzle's car as well, very clean cars.
                Originally posted by Vex View Post
                Engine/Performance
                - F22A6 w/ 251,XXX Miles
                - 1/13/12 : 255,XXX
                - 4/7/13 : 259,XXX
                - 5/7/13 : 261,XXX
                - OEM PT6 ECU
                - Gates Timing Belt
                - Generic SRI "GunMetal" Tubing w/ K&N 3" Clamp On
                - Generic 4-2-1 T-304 Stainless Steel Header
                - OEM Honda Header Gasket
                - Ebay Down-pipe gasket
                - Ebay Cat Gasket
                - Yonaka 60MM CatBack Exhaust
                - Megan Racing Resonated Test Pipe
                - FRAM Oil Filter
                - Mobil 1 Fully Synthetic Oil
                Transmission
                - H2U5 F22 5 Speed Transmission
                - Honda OEM MT Fluid (Changed @ 258,XXX)
                - Stock OE/OE Replacement Clutch
                Suspension Work
                - Function Form Type 1's (Put in @ 254,XXX)
                - 2" drop all around. (I think.)
                - 93 Accord EX Alloy Rims (Uninstalled) Winters
                - Couper CS4 Touring Tires. (Uninstalled) Winters
                - Drags DR-19 16x7 +40 Offset
                - Kumho ECSTA AST 205/45-16
                Interior
                - Pioneer Head Unit w/ AUX & USB iPOD
                - Pioneer 6x9 Rears / 230W @ 50RMS (Removed)
                - Alpine Type E 6x9 Rears / 300W @ 75RMS
                - Pioneer 6 1/2 Fronts (Usually disabled to give the rears all the power.)
                - OEM 92 LX Front Speaker Pods
                - Koiler 420W / Dual channel amp ( Given free from friend )
                - Alpine Type S 12" 1500W ( didn't want one these big but got it only for $80 incl. box )
                - OEM Maroon Honda Floor Mats, Drivers, Passengers and Both Rear Passengers
                - OEM Shift Boot + Knob (Uninstalled)
                - Black Suede Shit Boot
                - Spoon Sports Duracon Shift Knob
                - Maroon Front Dash Mat
                Exterior
                - OEM Front Mud Flaps
                - OEM Rear Mud Flaps
                - OEM Rosewood Paint Job
                - OEM Sunroof Visor (Uninstalled)
                - OEM 92-93 Stanley HeadLights w/ AutoVision 6000K HID
                - OEM 93-93 Stanley Corners
                - OEM 92-93 Stanley Amber Bumber Signals
                - Tinted Windows
                - 94-95 Accord Mugen Style Lip
                - Plain black license plate holder w/ CB7Tuner sticker.
                - SickSpeed Red Anodized 2x 10MM Dress up bolt (used for lis. plate holder)
                Trunk
                - Spare Tire (Removed)
                - OEM Honda Jack (Removed)
                Plans Accomplished
                - Fixed corner/turn signal problem : Blown Bulbs
                - Minor Engine Degreased
                - Installed coils on 12/16/12.
                - Ordered CAI. 12/27/12.
                - Installed Lip 1/24/12.
                - Installed Rims 1/25/12.
                  i nominate Dayzielynn. A lot of work has been put into this car and i think its one of the nicest cars on this site!
                  http://www.cb7tuner.com/vbb/showthread.php?t=199031
                  Motor:
                  stock f22a6
                  Megan racing header
                  password jdm egr block off plate blue
                  aem intake
                  full wire tuck and motor bay shave painted pink pearl with rainbow flake
                  AC deleted
                  cruse control deleted
                  battery relocated in trunk
                  Exterior:
                  painted off white with white diamond pearl
                  rare jdm Authentic one piece headlight with chrome trim
                  rare usdm Authentic fogs
                  rare jdm Authentic rubber trim inserts for fogs
                  rare jdm oem Authentic Honda Coupe door visors
                  rare oem Authentic Honda sun roof visor
                  rare oem Authentic honda hood bra and full nose mask
                  thule roof rack and fairing
                  carbon fiber mugen lip
                  carbon fiber hood
                  carbon fiber trunk
                  50/50 spec d tail lights
                  jdm side marker
                  rear fenders rolled
                  jdm Authentic 90-91 rear mud flaps
                  jdm Authentic 92-93 grill with custom pink resin emblem
                  Interior:
                  stock maroon interior
                  black sparco bucket seats
                  rjs pink 5 point harnesses
                  tinted 15% front and rear
                  Audio:
                  POWER ACOUSTIK deck
                  JBL front and rear speakers
                  2 12in pioneer subs
                  2000 watt kenwood amp
                  Wheels and Suspension:
                  Klutch sl1 wheels powder coated pink pearl
                  tokico illumina struts
                  ground control coilovers
                  ingalls front and rear camber kit
                  polished Megan racing control arms and toe
                  Future plans:
                  to have all the rare oem jdm Accessories for my car still need the car cover and a few more things but off to a good start
                  fully built turbo h22a type s red top
                  5 speed swap
                  se dash
                  charge speed grill
                  pink roll cage
                  repaint motor bay and fully shave it when h22 gos in
                  all password jdm motor and fender dress up kit
                  password jdm pink tow hooks
                  5 lug swap
                  real bbs rs wheels 5 lug
                  real WORK Meister S1 wheels 5 lug
                  klutch sl1 same as i have right now but 5 lug
                  fender wells painted black
                  all my knuckles powder coated pink
                  beaks tie bar
                  and much more
                  Originally posted by scudweiser
                  i farted while i was getting head once, i was drunk.
                    This is someone who has impressed me recently.
                    bassrock234 : 1990 Accord EX
                    Engine/ Exhaust:
                    F22a4
                    short ram intake
                    Wheels/ Suspension:
                    Autostrada Modena 16x7 16x8
                    Dunlop DZ101 195/50/16
                    Function and Form Type 2 coilovers
                    Ingalls ball joint front camber kit
                    Eibach rear upper control arms
                    Prothane Bushings
                    -Front and rear sway bar
                    -Front lower strut mount
                    -Front lower control arms
                    -Front upper control arms
                    -Ball joint and tie rod boots
                    New wheel bearings and hubs
                    Blackworks extended wheel studs
                    Muteki Extended lug nuts
                    Sprint suspension front strut tower bar
                    Ebay rear strut tower bar
                    Brakes:
                    Apex stainless brake lines
                    Exterior:
                    Black housed oem headlights with Yellow high beams
                    Blackhoused oem corner lights
                    Blackhoused oem bumper lights
                    JDM CB sidemarkers
                    CD5 rear sidemarkers
                    Ebay window visors
                    92-93 Sedan Trunk with oem led spoiler
                    Jack Lee grill
                    55w 6k HID low beams
                    35w 3k HID high beams
                    Acura Legend coupe lip
                    Oem front and rear mudflaps
                    Interior:
                    Nardi woodgrain steering wheel
                    Prelude short shifter
                    Ebay green shift knob
                    Ebay black suede shift boot
                    Pioneer headunit
                    Pioneer 6.5 door speakers
                    Pioneer 6x9 rear deck speakers
                    Pioneer 1in door tweeters
                    Oem 90-91 arm rest
                    Broadway 270mm rearview mirror
                    "My FOR SALE thread - Click here"
                    MEMBERS RIDE
                    99 SILVERADO
                    WHEEL FLIP
                      Lots of nominations pending, but no acceptances. Don't forget voting starts soon.
                        Nominations Closed
