Its in AND running. Going for the tune, then sleep for a couple days, lol.
jdm92_accorn : 1992 Accord LX
alright guys, here it is, now it's nap time, lol.
this is with only 22deg timing, we usually run 25-26deg but apparently it needs a cap and rotor button pretty bad so monday i'll do that and see if it smooths out up top and we'll add the timing back in. so far so good on my cam profile. i might just slap the f22b dohc head on the other f23 block just to sell for now maybe regain some of my losses. anybody want a stock f23b dohc, lol?
Originally posted by jdm92_accorn View Postalright guys, here it is, now it's nap time, lol.
So you added about 6-7 ft lbs of tq? What was the setup again, 10:3:1 compression?“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Very first tear down and rebuild. vvv
http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755
Current Build, F23 block F22b dohc head:
http://www.cb7tuner.com/vbb/showthread.php?t=203144
Originally posted by jdm92_accorn View Postprobably the built sohc with 11.6:1 and my custom ground cam behind the t2w4. then the stock f23 bottom with the other a6 head in betsy and finally the dohc for my girl. she's looking into getting a 94-95 sedan for her dd so the dohc will be her weapon of choice.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Originally posted by Mishakol129 View PostI would like you to get into the 250 whp range with the F23, do you think 11:6 compression will get you there?
That's really good man. I wonder how that affects your 0-60 and 1/4 mile times. You got a bullet there now. Put it in a Civic though and then it'll be insane. That's if you like Civics.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
at this point it's fairly useless power. it just spins a whole lot. it feels great in higher gears though. nothing like accelerating in 5th as if it were 3rd. i think im going to definitely end up with 6 coilovers, one front set of 12k's and a set of 6k's and 18k's for the rear. that coupled with a T2W4 trans and a better shifting setup should put it in the low 13's to high 12's with some good driving. best so far was high 13.7's with 1.95 60ft and that was at 206whp with the open diff M2S4 trans.
I like what youre doing here man, keep it up.
That being said, i added 2 degrees of timing to my h a couple weeks ago and it woke up. Seeing what you gained really makes me want to get back on the rollers seeing how on the basemap alone i put down 203.1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
My Workout Log
Originally posted by LeungWell, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
With that latest dyno chart, it's time to update your sig!
I think that with this current setup, you should head to the strip with a set of M/T ET Sport Compact Drag radials or slicks on some lightweight racing wheels and see if you can dip into the 12's.
MRT
14.38 @ 98.66mph
Current fastest Laguna Seca Lap: 1:52.346
