Hey accorn, do you know if the internals of the JDM MP1A are the same as the USDM MP1A? what are the differences? I'm asking because the shop i want to have rebuild it wants to know if the clutchpacks and gears are identical, or would they have to find the parts from JDM Honda stuff. Is the only thing different the larger casing to fit the different differential?
jdm92_accorn : 1992 Accord LX
Originally posted by jdm92_accorn View Postthats what im saying though. i might try to go after that title, fastest N/A F22 accord.
The Caravan 2015
I don't have to beat bisi. I just want fastest n/a f2X in a CB7 chassis. A f series in a 1700lb chassis with 415whp+ is pretty tough to beat. It also runs on methonol and behind a dogbox d series trans which those two alone are good for a 5-10% gain in hp plus the 5% reduction in parasitic loss through the drivetrain. So on E85+toluene through a t2w4 trans built up that same engine would be about 374whp. I'll low ball mine to be making 340whp which would put a drag prepped 2300lb car in the low 11's with a good 60ft, ie sub 1.6sec.
Originally posted by P5ylance View Post^gaaat damn.
Honestly I would say having the knowledge is way more important than having the funds. With due time you will have the funds.
The Caravan 2015
Originally posted by jdm92_accorn View PostGot a 70mm skunk2 throttle body. Also I found out my valves have been a little out of adjustment this whole time, lol. It made 201whp with the lash at .011in/.014ex and it should be .009"in/.011"ex. Also I've got a bad exhaust leak that might be robbing a pony or two.
The Caravan 2015
