jdm92_accorn : 1992 Accord LX
    The OEM mounts have open areas at the top and bottom. I'm not opening the window weld vs urethane debate. I'm suggesting attempting to make a mount similar to OEM with the open areas. Just using a harder urethane; window weld whatever.
    steve
      this actually doesnt sound like a bad idea, i may try it in the future. all i know is for now im just going to stay away from the track and granny shift a little more, lol.
        Am I good with stock fuel pump?
          I had a stock fuel pump at 171whp with no starvation issues at all.
            When I figure out how to do it. I will let you know. I need something to keep the area from filling up. I'm thinking of using some casting tape from work, but I don't know how I would get it out.
            Do wheels rub or do you have any trouble with them?
            steve
              Thanks! I was able to find and purchase the jdm lsd tranny
                Good deal bro. Cant wait till I get my lsd trans, lol.
                  yeah man, thanks for the support! without you I would've probably never got as far along as I did in the past 2 months in planning. I was able to grab up all the items I wanted for my build and now its just a matter of spending the money on the rebuild in winter, breaking in the motor and trans, and then installing the cam and springs over summer and tuning.
                    I have a question for you. Is that battery the stock size and is it supposed to be facing vertically? Mine on my wagon is humongo and faces horizonally.
                    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
                    ― Jeremy Clarkson
                    Very first tear down and rebuild. vvv
                    http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755"]http://www.cb7tuner.com/vbb/showthread.php?t=193755
                    Current Build, F23 block F22b dohc head:
                    http://www.cb7tuner.com/vbb/showthread.php?t=203144
                      Cool was it 20 year old pump?
                      ― Jeremy Clarkson
                        obviously not. its an aftermarket odyssey battery. he made his own battery tie down/bracket so it could sit like that.
                        C-3PO's MRT USDM yo!
                          Lol, yah.
                            You gotta get that 3in exhaust and jump on that dyno again... I wanna see a single cam in the top 5.
                              I want to make a few changes before my next run on the rollers. I'd like to hit 205whp on the superflow dyno.
                                I meant to share this earlier.
                                http://www.cb7tuner.com/vbb/showthre...19#post3171219
                                14.03's, I'm getting closer. Now its time for a new clutch, lol. After this run it consistently got slower due to clutch slip.
