jdm92_accorn : 1992 Accord LX
    lol I'm retarded sometimes. Your professional products looks exactly like my Skunk II TB in every way.
    The Caravan 2015
      it pretty much is. only diff is the skunk2 is probably cheaper, lol. i payed $115 i think for mine new about 4+ yrs ago. i wish someone would buy my dag on manifold so i can fix my car faster, lol. also by the way i thought id share some tech info.
      if you want to see whats the best intake and tb setup for your street engines here's a few formuulahs(formulas, lol)
      side notes: intake runner on f22a head is 3.6" so this needs to be figured into intake manifold runner length. ie, if you need a 13" runner length for the power band you want you need to subtract 3.6" from it. so 13.0"-3.6"=9.4" intake manifold runner length.
      VE= volumetric efficiency (95 for most street hondas)
      DL= displacement in liters
      DC3= displacement in cc
      PTR= peak torque rpm
      SQRT= square root
      ^(2)= squared= the number times itself
      (intake plenum size)= .6-1.3 x (DL) on n/a and 1.5-2 x (DL) on turbo. larger plenums offer more hp and torque potential but smaller offers better response. its your preference.
      (ideal total runner length)= (84,000)/(PTR)
      (ideal runner diameter in mm)= ((SQRT [((PTR)x(DL)x(VE))/3330])x.1) x (25.4)
      (ideal throttle body size in mm)= (SQRT [ ((154.2)x(# of cyl)x(stroke in inches)x(redline rpm)x((bore in inches)^(2))/67,547])x1.15
      (ideal intake tube diameter)= 1.15 x throttle body size
      examples of my setup:
      peak torque: 4900rpm
      redline: 7500rpm
      bore: 85mm or 3.346"
      stroke: 95mm or 3.74"
      #cyl: 4
      displacement in cc: 2156 or 2.2 liters (technically 2.156L, lol)
      aspiration: natural
      my ideal plenum is .6 x 2.156L = 1.3L plenum (skunk2 pro h22 I.M.)
      my ideal runner length is 84,000/4,900 = 17.14" then 17.14-3.6(f22 intake port length) = 13.5 in (skunk2 pro h22 I.M.)
      my ideal runner diameter is ((SQRT[((4900)x(2.2)x(95))/3330])x .1)x(25.4) = 44.5mm (skunk2 pro h22 I.M.=50mm but is port-able up to 54mm)
      my ideal throttle body is (SQRT [ ((154.2)x(4)x(3.74)x(7500)x((3.346)^(2))/67,547])x1.15 = 61.58mm (oem S2000 throttlebody)
      my ideal intake tube diameter is 1.15 x 62mm = 71.3mm or 2.8"(AEM V2 prelude intake)
      lol, now you know how i make good power and how i made my decisions on my parts. there's a whole other part to tuning frequency chambers to create an air supercharging effect.
      now this math is not for the faint of heart. if you're having a hard time understanding it just let me know and I'll help.
        Numbers make my head hurt.
        KEEP IT NICE, NOT RICE
          lol. its not for most. i promise you though, this math works. my best whp was 175whp and 162wtq on a bone-ass stock f22 with a camshaft (barely larger than a stock f22a6 cam) and I/H/E/IM. i changed my mind on the whole 4-2-1 front for my setup aswell. im actualy thinking about staying with a 4-1 header because my future build plans are for the higher rpms. i want to get another CB7 coupe but i want the next one to be a DX model. i want to do a 2400lb cb7 with an all motor F-series. truth be told i've thought about converting the DD into a K20A-R. cant argue with the results. a k20a type r from hmotors is about 5k. a swap header, mounts, fuel system, kelford stage-1's, bored tb, and kpro is about 3k. $500 for ac liof nes and misc. but for 8.5k i can have all the luxuries i had with my stock accord lx with the benefits of 35+mpg, 260whp,165wtq, 6spd and the 9k rpm soundtrack. plus the fun factor of maxing out the 8k tach. this coupled with my varex muffler and the prelude blades would make for a great sleeper. 260whp + 5.0 jdm crv final drive = high 12's in a cb7 all motor with a very streetable stock engine.
            Bro, your typing at a 100mph. Looks like I'm all ass backwards. I love the numbers info. I'm going to have to go through that posting very slowly and hopefully I can absorb it.
            The Caravan 2015
              lol. one day i'll sit down and consolidate some header fomulas for you guys.
                funny story, i found a f23 that runs pretty good on craigslist for $150. so i went to go pick it up and low and behold he's got a 95 accord that he pulled it out of to put in his h22. turns out he also has a f20b head that is in perfect condition. so i wonder how hard it would be to put a f20b head on a f23 with k20 pistons.
                  Sounds like it might be fun with a nasty set of cams and your intake. Should set you around 215whp
                    The same amount of work needed to adapt an H22A head to an F-series block. The PCB casting is nearly identical with the exception of the P13 head with the exception of the smaller diameter combustion chamber.
                    I have pictures of it in my Frankenstein thread.
                      well i made the decision. i ordered another level 2 bisimoto cam and a bisimoto cam gear. next wednesday or thursday i'll be ordering a f23 from jdmenginedepot.com and will be posting the head for sale to recoupe. im tired of looking for a good block locally. i've spent way too much time in junk yards pulling heads just to find worn out bottom ends. then i'm going to pull a f22a6 cylinder head and have it cleaned up, put in new valvesprings, new oem honda retainers and keepers and have it rebuilt. i want to port it but budget wont allow it. so basically it will be the same as the f22 with a larger cam, higher compression and a bump in displacement by roughly 100cc. wish me luck.
                        well my brother put me up to a challenge a few days ago. he is convinced his sr20ve with I/H/E is going to out run me, although he does have about 7-10wtq more than most ve's. lets see what you guys think.
                        sr20ve i/h/e/tune in b13 2310lbs with driver
                        mine before i/h/e/im/c/tune cb7 2881 with driver
                          I think you should get him after 2nd gear, is it just me or does it seem like he's choking high RPM?
                            it seems like it does a little bit. its mainly the header most of them run. it's made for a regular sr20de not the ve so it bottle necks at the collector. but still, its quite a bit lighter. well i ordered the block for mine tonight. anyone looking for a vtec sohc setup, lol.
                              Yeah, I'm pretty sure you'll get him. Either way when your car is up and running again, race him and let us know!
                                well i ordered a remaned cylinder head today. hopefully the engine and head will be here sometime next week. damn im ready to get my car back.
