whoops sorry about that Colin, I could have sworn that i replied...oh well
Is your idle unsteady?
- The startup and cold idle is fine, no issues. After driving the car, I get a slight 'blurping' from the exhaust, idle does not change on the guage, but it has a blurping cam type sound after its been driven or revved. I had this issue on my old motor (B1) after it had been driven on the map that I provided you.
What plugs are you running?
- NGK V-power 7173's, should be -8's which is 3 step colder on the F series.
When you mash the throttle, are they holding the 11.7-12.3 afr's through boost or transistioning into boost?
- Yes pretty steady, if they change its very slowly and gradually. Numbers on my wideband meter do not jump all over the place.
I believe when I first put in the map, it had no changes accept the wideband pin output. Only changes I have made since then are richening the boost tables from 0psi on up by 2 clicks.
So that cut off I hit in 4th gear before, that was the boost cut or lean protection? I only hit 7.8 psi on my boost sensor readings (from the wideband unit)
