Haven't had a lot of time to work on this one. I had it running as described earlier, but once it got warm, at least one valve started to stick. Finally pulled the valve cover off the other day and the top end of two exhaust valves didn't line up well with the screw on the rocker arm. I was able to "nudge" them back into the correct position and have had no further issue with sticking.
Still have to work on hard starting: it cranks fine, but only randomly fires, it takes several attempts of extended cranking to finally get it started. Once running, it runs fine.
Also installed new front rotors, outer tie rods, and muffler. With the new muffler it is obvious there is also a hole in the B pipe, so I'll have to get one of those.
Visited an Acura dealer; they were able to provide me with wiring diagrams for the CL seats so when I get to the interior I'll have to run some wires for the driver seat.
