sonikaccord : 1992 Accord EX
    Heck no!! I live in the south (Atlanta), but it does get cold. I don't like working in the cold unless it's necessary, like car won't run necessary. Plus I get to stay inside and work on geek stuff like this:
    And when it snows down here...everything shuts down...I took this picture last year during the snow storm where everybody went ape shit at walmart and this is what was left:
    I got some drill bits in to put some reliefs in the wheels, they don't have to be deep (<10mm) but they need to be able to fit the spacer lug nut as well as the lug itself so I'll do a countersunk style hole.
    Also USPS lost my resolver for my stacked IMA project!!!!
    YouTube Clicky!!
      What's the disc with the red thing hooked to it?
        It's a Bridgelux Vero29 COB LED aka really fkin bright light.
        I want to throw it in a low beam projector
        YouTube Clicky!!
          Man, come on United States! I'm kind of glad sometimes that I spend the extra money and go with UPS.
          MRT
          14.38 @ 98.66mph
          Current fastest Laguna Seca Lap: 1:52.346
            i bet itd work well, i wonder if it can handle a low operating temperature. was it sinked or u just using that as a stand?
              USPS has no affiliation with teh federal government :P all their income is through postage.
                Yep. I think it's rated for -40C to 80C any temp above that will reduce its lifetime...it's in a car so I can tolerate 5000 hrs of life.
                20,000 lumens for a pair would be nice to show off.
                YouTube Clicky!!
                  Ah.
                  Are they as bright as a quality HID kit in a projector?
                    If you compare the bulb without the optics, the LED destroys the Xenon bulb at full power. At the same power it is still brighter.
                    With the optics may be a different scenario because of direction of light that is emitted. (360 for xenon, 160ish for the LED). If you've seen the projector design for modern led headlights, they usually use multiple leds aimed in several directions to get that smooth flood light and for more brightness. Like the new MDX or RL, Prius, etc.
                    YouTube Clicky!!
                      Ah, ok.
                      Are these leds much more expensive than hids? Led lights would be a cool alternative for a retrofit if it's feasible.
                        Maybe...
                        I just went to www.theretrofitsource.com to skim some prices. The hid bulbs and ballast are roughly $150-200.
                        Those leds are $30 a piece right now. I'm currently designing a high efficiency driver for them as they need about 40V to run. That'll cost about $150 max in parts for the pair. Then there is still the projector issue. But it doesn't look like too big of a cost difference.
                        Oh and don't forget the heat sink when you feel like overdriving these things 200+ watts a piece.
                        YouTube Clicky!!
                          Dude, thanks for mentioning that you ordered from Majestic Honda a little while ago. Man, I went there recently to check it out and ended up ordering a bunch of stuff! The layout is awesome and I am thoroughly impressed with the inventory!
                          MRT
                          14.38 @ 98.66mph
                            Yeah! For OEM parts, they are the standard imo.
                            YouTube Clicky!!
                              Man I wish I could understand all the lingo you said in this thread. Your ideas are not only spectacular but revolutionary. Keep up the great work.
                              ~Nick~
                                20,000, lol..... kind of much
