Originally posted by Dy2*STR33T-KING
View Post
Dy2*Str33t-King : 1991 Accord EX (2)
Originally posted by Dy2*STR33T-KING View PostIM not worried about the rust it's only on the body.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Clean_4th gen View PostSwap glass with your current lights. They're the same year. Should be a direct fit.
UPDATE
Just had rotors turned and new brakes installed at dealer for 140$ cash
Also just purchased integra palmy blue headrests 8)
Wish I had honda door mats**Blk Housed Slut Crew Member #1**
So I decided to go with the best plugs on the market. I ordered a set of Pulstar plugs to replace my Denso Iridium that I've ran for about 40k miles in my other CB. Needless to say this will be a much needed upgrade.
What the Denso look like
Here they are in comparison
Started raining as I got them out so I will install once it stops and give you guys some feedback. I did have a slight hesitation and felt like power would cut in and out at times so we will see if this helps.
Getting a cap and rotor kit from Honda this Friday and then a set of wires to complete the basic ignition tune up.Last edited by Dy2*STR33T-KING; 08-02-2013, 04:59 PM.
Your interior is really clean. 91 EX coupe interior is about as rare as they come. I didn't realize this myself until Jarret pointed it out to me. Ever since then I have made countless trips to the JY in hopes of finding a rear seat bottom that is cleaner than mine only to be left with disappointment. I haven't come a cross one in 2 years of searching. I have tried cleaning mine the best I could but I haven't sucessfully been able to.
The damage to your other CB didn't look that bad honestly. I know it doesn't take much to total out a CB from insurances point of view. But the overall condition seemed pretty good. A few trips to the JY and I believe it could of been repaired rather easily.
The Caravan 2015
Originally posted by SanJoCaF22DrAcc View PostYour interior is really clean. 91 EX coupe interior is about as rare as they come. I didn't realize this myself until Jarret pointed it out to me. Ever since then I have made countless trips to the JY in hopes of finding a rear seat bottom that is cleaner than mine only to be left with disappointment. I haven't come a cross one in 2 years of searching. I have tried cleaning mine the best I could but I haven't sucessfully been able to.
Interior is really clean!
That rust that is on both sides of your car, in front of the rear wheels is more than just surface rust. You might want to take the rocker guards off and check the rocker/frame of your car before you go spending money on over priced engine parts.
If those spark plugs are any indication of the previous owners regular maintenance. I would be very weary of putting money into that engine. I can only imagine what the inside of the valve cover looks like. probably never changed the oil.
I would be looking into the basic maintenance of this vehicle before spending money on mods. Just my 2¢!
New timing belt at 140k it's at 177 now. New cv axle on drivers side and new front end links. They also told me all the ball joints and rest of the suspension looked great and everything was tight. Only thing they seen was a ripped tie rod boot.
Why do you go to Honda for a brake job?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
