Niceee!
Darkcloud : 1990 Accord EX
Originally posted by Raf99 View PostNiceee!
So I had a little bit of time today, got the doors swapped out. Put the steering wheel in to see how it would look with the shifter. And a fender mod.
A little bit of interior mounting
So here is something I've been wanting to do i must say I like it, it's not where I want it but I'll get it right. Not sure If I should weld or use to eat. I'll pull the fender more out as I plan on running 30 offset wheels
I to like the fender idea.
I would do some spot welds on the back side to hold it in place, the on front side do some small stitch welding on low heat as 90s up you can really tell the metal has gone to crap really thin so it like to burn. Then use a angle grinder with some 36grit flap it will make shaping in the small area easier.
Then use some fiberglass matting (you can also use the 36grit flaps for shaping on this step) as it will hold up better than the thin hair or zglass. Then proceed to putting some mud on it and shape as needed with 80 or 180 depending on how well you spread mud. You can prime over 80 aswell just need to prime heavy. Once primed use some cheap krylon black as a guide coat it will help with sand scratches an highs an lows I like to sa my primer with 320 first then 600. Hope this helps.Last edited by SOHC-FTW; 03-18-2016, 12:48 PM.
02 Crv
Originally posted by Darkcloud View Post
Thanks everyone, I need to get a few things squared away before I finished this project, also planning an odd not so common build that won't include Tec, yes I know Tec is everything these days but Oh well. Just keep an eye out
How does your shifter linkage fit under the plastic? Mine bumps into the little tray in front of the shifter.Bought from: Night Wolf, bassrock234, sonikaccord, 904drACCORDMANG
92 Accord, F23a franken-engine, N/A forever.
Originally posted by dwhacks View PostHow does your shifter linkage fit under the plastic? Mine bumps into the little tray in front of the shifter.
Haha sorta, that post was a joke though, I just don't have upper arms in the rear, not sure if I want wicked rears since they bent on me or installs, I it would be awesome to find racing type arms that can take abuse. I do need trailing arm bushings I heard hard race fits but I can't remember who was mentioned.
I wish ronald type r was on the site still, I know he did something's but his pics don't work.
As for updates I'm waiting for stuff to arrive,I will say I got rods and valves in the mail.
I figured something was taken out of the back end... I spied those arms on the ground behind the car! There's a 9th gen Civic sedan on my street that has stupid camber to fit some low offset mesh wheels. Rear angle is almost the same as your joke photo. It looks terrible. Even worse is that the owner looks like they pulled the fenders with a crowbar... Shameful.
That's a good shipment there!
