A little bit of shortening and reshaping
lucifer1 : 1990 Accord LX
Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Guy is sick with wiring and electronics.**Blk Housed Slut Crew Member #1**
Originally posted by lucifer1 View PostA bit of nipping and tucking gained 1.25" of rear wheel travel.
WOW! I would like to see what you did to your rear barrels to have the much clearance.
Originally posted by lucifer1 View PostA little bit of shortening and reshaping
Is that the front knuckle? holy shit you definitely reshaped it.
Trimmed and reinforced rear upper arms
I want to see it finished also but there is a lot work still aheadManual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Sema car I am wiring up
A little tire bump
Plated/reinforced spindles
I looked at my set of Odyssey knuckles when I had them off of the car and tried to envision a way to make drop spindles while keeping the same size wheel and tire combo and couldn't come up with anything. You, sir, do amazing work. I'd very much like to see some comparisons between this spindle and the factory one if you have a spare.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
This is the only comparison picture i have
These are just shortened at the top, they are not drop spindles. Drop spindles should basically move the hub upward while maintaining stock geometry. This is great if only lowering an 1.5" but if you want to be low it actually is harmful. You will lose the camber gain needed for tires to tuck and turn when very low. Unless you are building from scratch, you will have lower ball joint to rotor contact issues.
I also lengthened the a-arm eye mounts the same amount to keep the geometry as stock as possible. Unfortunately this caused an excessive ball joint angle so I am going to use unmodified ones.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
I still debating 5 lug or 4x100. It will be determined soon when i get the new brake setup sorted out.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
