Engine:
Block:
'93 JDM H22A
Benson sleeves installed by Benson
Benson crank (polished and balanced)
Removed Balance Shafts
Removed Oil Squirters
Pauter X Beam Rods
CP 10:1 CR Pistons
ACL Race Bearings
KS Tuned Timing Tensioner
ATI Super Damper
Greddy Timing Belt
Oil Pan Modified for Oil Temp
Blueprinted
Head:
'00 H22A4 PDE Head
3 Angle Valve Job
Supertech Valves
Supertech Springs
Supertech Ti Retainers
Supertech Bronze Valve Guides
'93 H22A Cams
Externals:
Removed IAB
NGK Iridium Plugs
New OEM NGK Wires
New OEM Coil
New OEM Igniter
AEM True Cold Air Intake
Apexi World Sport 2 Cat-back exhaust system
Magnaflow Hi-flow catalytic converter
Feel's Header
Koyo Aluminum Radiator
Carbon Fiber Radiator Brackets
Engine Bay Dress Up Hardware
Electronics:
Hondata S300 V3 with Boost Control
Innovate Motorsports MTX-L Wideband
Innovate Motorsports MTX-D Oil Temp and Pressure
Innovate Motorsports MTX-D Voltage and Water Temp
Custom Built Engine Harness
Custom Built Chassis Harness
Custom Fuse and Relay Board (Pegasus Racing)
SDash custom Galaxy Tab Instrument Cluster
Drivetrian:
H2A5 5 Speed Transmission (Backup)
M2Y4 Synchrotech Built 5 Speed Transmission
Carbon Synchros 1-5
Polished Gears 1-5
MFactory Mechanical LSD
MFactory 4.64 Final Drive
MFactory Billet Input Shaft
OE Prelude Clutch (removed)
Fidanza 7lb Flywheel (removed)
Competition Clutch 9lb Flywheel
Competition Clutch 6 Puck Stage 4 Unsprung Disc
New OE Clutch Master/Slave
Custom Braided Steel Clutch Line
New Front Wheel Bearings
ESP Engine Mounts (Wrinkle black, red insert) (removed)
Innovative Mounts 90 Duro Red Bushings
Suspension/Dynamics:
Skunk2 Springs (removed because they suck)
Tokico Blues (removed)
Prothane Master Bushing Kit
New OE Upper Control Arms Front/Rear
Ingal's Front Camber Kit (removed)
Function Form Type I Coil Overs
New Rack and Pinion x2
Falken Front Strut Bar
New OE Tie Rods
ST 27mm Front Anti-Roll Bar
Progress 22mm Rear Anti-Roll Bar
FFC Rear Lower Control Arms
Wheel/Tire/Brakes:
Konig Blatant 17x7
Kumho Ecsta AST 215/40/R17 (Removed)
Michelin Pilot Super Sports 215/45/17
Momo 15x7 with studded 195/60/15 for winter (Removed)
TAS Auto 11.1" Front BBK Conversion (calipers/rotors/pads)
TASPRO Stainless Steal Brake Lines
HAWK HP Plus Front/Rear
Wilwood Adjustable Brake Bias
Custom built brake Lines
Interior:
Fully Gutted (No door windows)
CL-1 Type R Recaro Seats
Wedge Seat Brackets
Exterior:
One Piece Headlights
Smoked Corners
Yellow Stained High Beams
Audi A6 HID Retrofit 6000K
JDM Yellow Foglights
Accord Inspire Side Markers
Honda Window Visors (Wrapped in 3M Di-Noc)
Hella Supertones
Greddy Gracer Prelude Lip (Destroyed)
Timeline:
9/7/10:
Purchased
All New Fluids
New Coil
New Igniter
9/17/10:
TAS Auto Big Brake (11.1") conversion with rotors, pads, calipers.
Rear pads and rotors
Stainless Steel Brake Lines
New Brake Booster
10/5/10:
3/14/12:
Prothane master bushing kit
All new control arms
All new ball joints
All new steering linkage
3/17/12:
New Blower Motor
3/23/12:
Dress Up Hardware
3/24/12:
New Cruise Control Module
Permanent AC/DC Power Converter
7/25/12:
Function Form Coilovers
New brake booster
New rack and pinion
New P/S pump
9/4/12:
AEM true CAI
HAWK HP Plus front and rear
9/5/12:
Magnaflow HI Flow Catalytic Converter
Apexi World Sport 2 Cat-back system
9/12/12:
Progress Rear bar on back order until late October.
9/19/12:
Feel's Header
12/8/12:
DDM 6000k D2S
3/16/13
5 speed trans
Prelude clutch
Fidanza flywheel
Clutch master
Slave cylinder
Honda MTF
Honda power steering fluid
Custom braided steel clutch line
4/6/13
Progress rear sway bar install
6/15/13
Kenwood Deck
Alpine Type-S 6.5
Xplod 6x9
Innovative Engine Mounts
CEL jumper switch installed
Hella Supertones
10/3/13
Greddy Gracer Lip
ESP F22 Auto to 5SPD mount kit
7/8/2014
PS1 mounted, balanced, roadforced
How she looked when I got her and how she looks now:
