Nice man...your ride takes me back.... My baby was looking like this -the rack...
Tippey764 : 1992 Accord EX (2)
This topic is closed.
Originally posted by P5ylance View Postthe leather insert is that easy to replace!? damn I wish I had me a set. can't find anything out here!
Originally posted by Tippey764 View PostAll you need to do is take out the panel and rip the old cloth off and glue the new peice on. You really need a tan interior though. Blue sucks lol.
Originally posted by agol View Postdid you do the wiring yet?
I wired the driver seats powered feature up so i could adjust it to drive ( passenger seat is manual )
I ran 2 wires, to the interior fuse box OPTION B spot
I solderd blue and red together and they both go to OPTION B and i upped the fuse to a 20 amp to handle the seat
I solderd both grounds together and ran them to a ground near the fuse box used by other things
It looks like an OEM accesory powered seat harness if they existed.
Originally posted by '93CB7Ex View Posthowd you hook the heater up? did you use your switches?
All i need to do is hook the switch to 12 volts and run a wire to the white wire, press of the switch will complete the circuit and close the rely alloying the seat to heat up.
I haven't started on the heated seat yet though.
